Hello all
i have my mikrotik RB2011 with ip x.x.x.x
i have connected i storage Seagate expansion for the cache on disk web proxy
but i have a issue
the disk not recognized by the mikrotik
before to connect the disk to mikrotik,
i have
- formated that to fat32 format
- add system routerboard usb set usb=mode=force-host
but not working
can you help me please ??
waiting your reply
Best Regards
Are there any logs?
RouterOS generally supports all mass-storage devices which Linux kernel support. I had some issues with Seagate USB<>SATA converters on Linux in the past (they were detected but no partition can be read).
hello,
thanks for your reply,
i don’t have the logs,
but when i do
"system resource usb print " i see my device connected but i can see that in the /System/Disks
first i have format my disk Segate to the fat32, this format before to connect to the mikrotik it is ok??
waiting your reply
Best Regards
Yeah, fat32 will be fine but ensure there’s a valid partition table and not fs on whole drive. Also ext4 filesystem will be better for RouterOS.
If you’re using linux connect the drive and type:
fdisk --list
Then you have to find your drive node, it will be something like /dev/sdb or /dev/sdc.
Next reformat the drive:
fdisk /dev/sdX
Press "o"
Press "n" and keep pressing enter for default values
Press "w"
Press "q" if program didn't exited
mkfs.ext4 /dev/sdX1
Now you can plug the drive into mikrotik. If it’s still not detected try another drive, even a pendrive - like I said Seagate USB drives are problematic sometimes
