Disney+
Hello, i wonder if any else have problem with Disney+, for a couple of weeks ago it worked just fine, then i upgraded my router to 6.47.6 and i cant log in anymore on Disney plus login page, the page is all black.
When im on VPN to my work it works just fine, i have tested 5 different computers and no one works. When i run F12 in Chrome i se a lot of 403 errors on the login page.
I have not done any thing in the router more than update it.
Can i see in the logs somewhere if something is blocked?
Router: RB2011UAS-2HnD
RouterOS:6.47.7
Country: Sweden
Hey,
You can send me or anyone else a supfie or export the router config so we can see if there is something specific.
The issues are limited to:
  • Routing
  • DNS
  • Firewall
Since you are receiving a 403 it’s probably not basic Firewall rules.
opps
I would remove the above file as this contains a little bit more then I would suggest you share.
Run /export hide-sensitive instead and post the output here.
However I have a all Mikrotik core at home and run 6.47.7 on all routers and do not have this issue.
I also reside in Sweden and all my units can connect to Disney+
The problem was not on my side, it was Disney+ that had blocked my Ip adress,
Why? Because my kid had forgot to turn off VPN when he tried to login on Disney+.
Disney+ doesn’t work with VPN. If they se that you try to login by VPN your IP will be banned.
This does not make sense to me. I mean if you use VPN Disney+ should not see your original IP address but only your VPN address. So how did they get your IP?
What VPN service was used?
