Display Probe warnings on separate lines
Does anyone know if there is a way to get probe warnings to display on separate lines rather than separated by commas. If you get multiple failures, your network object expands out horizontally across the page.
Hi there,
Actually I don’t know the answer to this question but I’m as curious as you about a probable solution.
It can really mess your map up when you have lots of configured services down on a device of which it’s label then gets screwed up.
Maybe it’s possible to align them vertically (don’t know that) or as some sort of pop-up when hovering over a device?
Guys, if anybody of you know a way to do this, we sure would like to hear/read it.
Regards,
Minollie
Here is an idea, this is not the exact solution but maybe a work around, instead of showing [Device.ServicesDown] on the label just remove it from the label. The device will still change color and you can hover on it to see which service is down but the label will not grow.
Click on left top settings button, select map, drop down device appearance, in the label box remove [Device.ServicesDown].
You can also do this on a single device if you want some to show on the label and some not…
Right click the device, select appearance, click label drop down, remove or add anything you want on the label for the specific device.
HTH,
SD
