Displaying submap outages on top level
Just wondering if theres any way to display 2nd level map outages on a top level map object.
We have a “Top” page that lists all our core networks and for this specific setup, all the objects under this node are links to other network maps
This causes an issue as the map itself shows:
No devices
no outages
and we have to dive down into the map to see any problems.
Is there any way to change the appearance to show these sub-level map stats?
I hate to bring up an old post but has there been any update to this or work around?
I am running Dude 4.2 beta.
We use a lot of submaps and would be nice to see the device status from a top level view and drill down where required.
Thanks.
Mark
No solution to this that I know of yet sorry, we opted to have all our submaps on one map of the country and setting the map to “Fit” mode (running v4beta03).
If you find anything yourself please let me know.
hello,
we need this too.
Is there any progress or workaround for this ?
