Disruption of real wlan interface when disable its Virtual AP.
We added a Virtual AP with its own SSID and Security Profile to a real wlan1 interface.
Our goal is to enable this additional Virtual AP SSID within a particular time period only.
So we are curently using these commands to disable and enable it via System → Script & Schedule:
/interface wireless enable VirtualAP1
/interface wireless disable VirtualAP1
It works.
The only problem is that when that Virtual AP is disabled or re-enabled, it will also disrupt the real wlan interface (master-interface=wlan1) for a few seconds (disappear then appear again). This would disrupt Zoom connections etc… for users on the real wlan1 interface.
I don’t know to to fix this? Or any other solutions?
