Hi thank you all for your support, I got it to work as you directed.
Now the other problem I am facing is linking the units wirelessly.
The distance between the AP and the station is about 15KM air mile.
I am using an Omni directional antenna on the AP and a station is a parabolic
antenna. The is clear LOS and I have moved the station from one direction to
the other but still no progress. I want to know far the AP Omni can
go. Do you think the distance between the Omni and the station is too much?
THank you and hope to hear from you views.
What kind of Omni antenna you guys using? dbi make model? these are posative feedback on the omni antenna! Im glad because I plan to use the same method of connection, however I have to be carefull on height and dbi of antenna… “The Doughnut”
