I didn’t get much response in my other thread so I’ll try to reprhase
How much distance are you supposed to get in reallife on a 7.4dbi omni with the RB/019 integrated AP/backhaul unit (atheros AR5213 card). And using 19dbi flatpanels as the CPE, with direct line-of-sight?
I currently get less than 500m. Noise floor in the omni is -79dbm. Signal in the CPE at 500m is -65dbm but it still does not want to associate…
is this normal? There are only 2 or 3 other APs in the area.
But if you have -76 in noise something is wrong!. i get at the maximum
-92 ! and then i have 3 diffrent GSM and 3 G tellcos 4-5 meters away
and a 2.4 Ghz WISP … but they ar running on V-Pol and im running on H-pol sectors 13 dbi…
So check your pigtails and cabels if not that check the radiocard.
Ok thanks. So at least I know I’m not completely crazy
now offcourse my problem is that the AP is in use so can’t remove it and don’t have a replacement at the moment…oops.
Incidently, the noisefloor on the backhaul is -101, but I don’t know if it’s only this good because it’s a flatpanel or what? I I get -101 on the flatpanel should I also get -101 on the omni? or is there a formula I can use to calculate what the noisefloor should be in the omni?
I think if you don’t have a hardware problem there must be a source of noise in roughly the opposite direction to your backhaul link,the panel would not pick up much from behind it.
Maybe as a test connect another panel to the cable going to the omni, scan around with it and watch the noise level
