DLNA Server issues, help please, I think this is very strange one,
Hi All
Its me again with another problem to solve. :slight_smile:
The back story: I have updated my friend LTE home internet link with a Mikrotik LTE 18 router all good after your help. but a strange issues has come about. my friend runs a DLNA server on a NAS which has been fine, but after i updated tothe Mikrotik LTE Router he cant see the DLNA server on his tvs etc.
Things To know:
  1. i have setup the DHCP and NAS and the router and access point to the same subset default gateway and network address range etc, and we can see all device and all devices can see the internet.
  2. i have reset the NAS and the LTE to default etc.
  3. rebooted the hardware ( powered off /On at the mains ).
  4. enabled UPnP on the router.
  5. he has a dump 5 port switch, i rebooted and swamped to a managed switch on defaults to see if it was that.
  6. i have tried putting the nas and access points use dhcp and static address to see if it was that, but nothing
  7. I have asked if he could move house because i feel he is on a lay line or something. he said no :frowning:
But the tvs and PC and consoles cant see the media server, but here goes the strange bit swap over to the tplink router and it all starts to work, i have even setup the tp-link router to use the 192.168.188.0/24 network to make my testing simpler, and i works fine.
I seem to feel like the Mikrotik router is blocking broadcasts, we have no vlans just one network, please don’t shout but i run a pfsense router at my house, and used the LTE18 router as a wan pass thought, before fiber came. so i never ran my network over RouterOS.
I have started to lose the plot a little. hoping someone has ideas to help. i can try and add the config if this helps.
Thanks again,
Adam
Yes, post the configuration, instructions here:
Forum rules - #5 by gigabyte091
# 2026-01-02 08:00:37 by RouterOS 7.21rc4
# software id = KFU4-8E8T
# model = LHGGM
add name=bridge1
/interface lte
set [ find default-name=lte1 ] allow-roaming=no band=""
add comment=defconf name=WAN
add comment=defconf name=LAN
/interface lte apn
set [ find default=yes ] authentication=pap ip-type=ipv4 use-network-apn=no \
    user=eesecure
add name=default-dhcp ranges=192.168.188.10-192.168.188.254
add address-pool=default-dhcp interface=bridge1 name=defconf
/queue type
add fq-codel-ecn=no kind=fq-codel name=fq-codel-ethernet-default
/queue interface
set ether1 queue=fq-codel-ethernet-default
/disk settings
set auto-media-interface=lo
add comment=defconf interface=lte1 list=WAN
add address=192.168.188.1/24 comment=defconf interface=bridge1 network=\
    192.168.188.0
add address=0.0.0.0/24 comment=defconf dns-server=0.0.0.0 gateway=0.0.0.0 \
    netmask=24
add address=192.168.188.0/24 dns-server=192.168.188.1 gateway=192.168.188.1 \
    netmask=24
set allow-remote-requests=yes
/ip dns static
add address=192.168.188.1 comment=defconf name=router.lan type=A
    ipsec-policy=in,ipsec
    ipsec-policy=out,ipsec
    established,related,untracked
    connection-state=invalid
add action=accept chain=input connection-state=established
add action=accept chain=input connection-state=related
add action=drop chain=input in-interface-list=!LAN
/ip upnp
set enabled=yes
/ip upnp interfaces
add interface=bridge1 type=internal
add interface=lte1 type=external
/ipv6 firewall address-list
/ipv6 firewall filter
    invalid
    icmpv6
add action=accept chain=input comment="defconf: accept UDP traceroute" \
    dst-port=33434-33534 protocol=udp
    udp src-address=fe80::/10
    protocol=udp
    ipsec-ah
    ipsec-esp
    !LAN
add action=fasttrack-connection chain=forward comment="defconf: fasttrack6" \
    icmpv6
    500,4500 protocol=udp
    ipsec-ah
    ipsec-esp
    !LAN
/ipv6 nd
set [ find default=yes ] advertise-dns=yes
/system clock
set time-zone-name=Europe/London
/system package update
set channel=testing
/tool mac-server
/tool mac-server mac-winbox
Hope this is ok?
You might want to make a little drawing here. DLNA “traffic” does not even “touch” your router so things like blocking “broadcast” are not at play here.
So NAS+DLNA is connected with 1 cable onto LAN-switch, the TV is also connected to the SAME LAN-switch and on that LAN-switch also 1 cable is running to the gateway/router ?? Simple home-setup like that ?? If everything sits in the same IP-range/correct mask then then it should work.
RouterOS has its own DLNA server, and it has settings that can cause it to be enabled.
But my reading is your non-MikroTik NAS is acting as a DLNA on the LAN.
IDK how, but you got lo got enabled for DLNA in your config that might be the issue. So to my eye, it looks like RouterOS is going to act as DLNA server. I can't think about why off the top of my head... but if you're not using RouterOS DLNA and having another DNLA elsewhere... likely best RouterOS does not enable DLNA on itself.
This should disable the automatic enabling of DLNA server:
/disk settings set auto-media-interface=none
Edited your config to remove serial number. Treat it as a secret as it is used by DNS service when you activate IP/Cloud.
Also this:
seems to me "peculliar"-
LOL, I didn't make it that far. But @jaclaz is right, the DHCP network is wrong, to fix:
/ip dhcp-server network set address=192.168.188.0/24 comment=defconf dns-server=192.168.188.1 gateway=192.168.188.1 netmask=24
I suspect this is caused bug in an older QuickSet that create a DHCP network with 0.0.0.0.
Yep, it is likely to be a collateral damage of Quickset, but there is already that 192.168.88.1 entry, it is only missing the (optional) comment=defconf.
The 0.0.0.0 one needs to be removed, but the 192.168.88.1 existing one is fine.
Rule #4 is there for a reason :wink::
The twelve Rules of Mikrotik Club
Hi Guys
Thank you for getting back to me so quickly.
Yes I did a quick setup, I will edit the config and see what happens.
Adam
Hi All
I have edited the config, please find attached, i have restarted the router and the NAS but no luck, any more ideas.
Adam
Please reformat postet config with proper < / > tag
# 2026-01-02 17:19:10 by RouterOS 7.20.6
# model = LHGGM
add name=bridge1
/interface lte
/interface lte apn
    use-peer-dns=no user=eesecure
/port
set 0 name=serial0
/queue type
/queue interface
    192.168.188.0
    netmask=24
set allow-remote-requests=yes servers=9.9.9.9
/ip dns static
/ip upnp
set enabled=yes
/ip upnp interfaces
    invalid
    icmpv6
    protocol=udp
    ipsec-ah
    ipsec-esp
    !LAN
    icmpv6
    ipsec-ah
    ipsec-esp
    !LAN
/system clock
/tool mac-server
