DLNA through VLANs with a RB2011 (Airplay)
RB2011UiAS
FW 6.49.2
Is it possible to use DLNA through VLANs with a RB2011? Or else with Airplay?
I’m using IGMP proxy routing for IPTV and that works fine (almost, if the CPU is not reaching above the 90%).
I’ve read that it ( DLNA through VLANs ) can be possible with some PIM configuration, but also that PIM can not be used with IGMP Proxy at the same time.
The configuration is a VLAN with a AVR and a VLAN with a mobile phone, I’ll stream the audio from the mobile phone to the AVR. (if they’re in the same network, it will work)
