DMZ-like setup
Hello everyone,
I just got a quick question:
Is it enough to dst-nat my external ip to an internal ip without setting any ports / protocols if I want to portforward everything? I don’t really need a DMZ with a different subnet, I just want all kinds of services etc to be forwarded from the external IP to a specific internal one.
cheers
sap
Yes, that would be sufficient in your situation. Keep in mind that you will no longer be able to administrate the router from remotely that way - which ultimately is probably a good thing.
yes, I’m aware remote configuration is not possible anymore, but that’s ok in this situation, thanks for the hint.
