dmz with public ips
i have 3 interfaces, WAN, DMZ, LAN
in WAN i use pppoe to connect with the provider.
The provider have giveme also and a extra /28 subnet with static public ips.
I want to take the extra public IPs in the DMZ zone (not 1:1 nat, but the real public ips in the servers in dmz)
Also i want to block some ports of this ips with the firewall.
How i can do this? all tutorials is with 1:1 nat in DMZ.
Deleted because not related.
If the extra /28 is routed to you via another IP range on your WAN link then you can simply use the extra /28 directly on the WAN interface and make sure that you are allowing necessary routing between the WAN and DMZ port in the forwarding rules.
