DNAT does not translated returned traffic
Hi everyone !!!
I have issue with DNAT
i created rule
add action=dst-nat chain=dstnat dst-address=ххх.ххх.ххх.ххх dst-port=64000 in-interface=ether1 protocol=tcp to-addresses=10.60.7.20 to-ports=22
it works in one direction, when traffic comes from outside
i see incoming traffic on 10.60.7.20 and responses to outside then i see returned traffic on router but DNAT does not translated back srcip and srcport to public ip
on all route some routers uses PBR but i think it does not affected traffic
jan/23/2019 14:57:09 by RouterOS 6.43.8
software id =
set [ find default-name=ether1 ] disable-running-check=no
/interface gre
add allow-fast-path=no ipsec-secret=xxxxx !keepalive local-address=xxx.xxx.xxx.xxx mtu=1400 name=xxxxxx remote-address=xxx.xxx.xxx.xxx
/ip ipsec peer profile
add dh-group=modp2048 enc-algorithm=aes-128 hash-algorithm=sha256 name=some_name nat-traversal=no
/ip ipsec proposal
add auth-algorithms=sha256 enc-algorithms=aes-128-cbc name=some_name pfs-group=modp2048
/snmp community
add address=xxx.xxx.xxx.xxx/20 interface=ether1 network=xxx.xxx.xxx.xxx
add address=10.140.64.2/30 interface=To_MKRHUB network=10.140.64.0
add address=10.140.64.5/30 interface=To_FAC network=10.140.64.4
add address=10.140.80.5/30 interface=To_FAC network=10.140.80.4
/ip dhcp-client
add disabled=no interface=ether1
set servers=8.8.8.8
add action=accept chain=input dst-port=161 in-interface-list=all protocol=udp
add action=accept chain=input src-address=95.182.74.14
add action=accept chain=input src-address=5.43.226.94
add action=accept chain=input src-address=10.140.64.0/24
add action=accept chain=forward src-address=192.168.10.0/24
add action=src-nat chain=srcnat comment="xxxxxxxxxxx" out-interface=ether1 src-address=10.60.7.0/24 to-addresses=xxx.xxx.xxx.xxx
add action=dst-nat chain=dstnat dst-address=xxx.xxx.xxx.xxx dst-port=64000 in-interface=ether1 protocol=tcp to-addresses=10.60.7.20 to-ports=22
/ip ipsec policy
set 0 disabled=yes
add distance=1 gateway=xxxxxxxxxxx
add distance=1 dst-address=10.33.0.0/18 gateway=10.140.64.1
add distance=1 dst-address=10.60.2.0/24 gateway=10.140.64.1
add distance=1 dst-address=10.60.7.0/24 gateway=10.140.64.1
add distance=1 dst-address=10.140.80.0/23 gateway=xxxxxxxxxxx
add distance=1 dst-address=192.168.10.0/24 gateway=10.140.64.6
/ip service
set telnet disabled=yes
set ftp disabled=yes
set api disabled=yes
set api-ssl disabled=yes
/snmp
set enabled=yes trap-generators="" trap-version=2
/system clock
set time-zone-name=Asia/Krasnoyarsk
/system identity
set name=xxxxxxxxxxx
add action=src-nat chain=srcnat comment=“xxxxxxxxxxx” out-interface=ether1 src-address=10.60.7.0/24 to-addresses=xxx.xxx.xxx.xxx
The standard dst-nat rule looks like:
add action=dst-nat chain=dstnat dst-port=xx
in-interface-list=WAN protocol=tcp to-addresses=192.168.y.yy to-ports=yy
Note1: If one has known list of WANIP authorized for access (static) then its best to make the rule more secure by adding a source address list.
Note2: If the destination port and to-ports are the same (no port translation, the too ports are not required).
In your case I dont think you need both destination address and in-interface=ether1 (try just using one or the other first). I dont think putting in both is required but on the other hand I dont see that stopping traffic, but worth a try.
This leads me to believe the source nat rule needs closer inspection.
The standard format is…
add action=masquerade chain=srcnat comment=“SCR_NAT for LAN Users”
ipsec-policy=out,none out-interface=eth1
Therefore I believe you rule should be modified to the following (drop everything after ether1!!!..
Dstnat and correct rewriting of responses is something that just works. There’s nothing to go wrong, unless there’s some asymmetric routing or something like that. I don’t see anything wrong in this config.
@anav: You like MUM presentations, don’t you? Check this one (notice the title and then from page 25):
https://mum.mikrotik.com/presentations/EU17/presentation_4058_1490948376.pdf
