Hi guys
Looks like I need a little help with the firewall.
Below you can see the exported configuration of my router.
My goal is to access from ethernet1 (WAN) interface to one host 192.168.99.3 (SSH/GUI) which is sitting in VLAN99 from the WAN 192.168.188.222
With current config, GUI was accessible for few minuts, Putty refuses to connect with error: “Remote side unexpectelly closed the connection”
For sure I am missing some rules on FW, could you tell me what?
Here is a full config export:
feb/11/2026 13:00:41 by RouterOS 6.49.19
Model = RouterBOARD 750G r3
add name=BR1 protocol-mode=none vlan-filtering=yes
/interface vlan
add interface=BR1 name=CCTV_VLAN vlan-id=10
add interface=BR1 name=MGMT_VLAN vlan-id=99
add interface=BR1 name=PPoE_VLAN vlan-id=88
add interface=BR1 name=WiFi_VLAN vlan-id=100
add name=WAN
add name=VLAN
add name=BASE
add name=CCTV_POOL ranges=192.168.0.100-192.168.0.254
add name=WiFi_POOL ranges=192.168.100.100-192.168.100.254
add name=PPoE_POOL ranges=192.168.88.100-192.168.88.254
add name=MGMT_POOL ranges=192.168.99.10-192.168.99.254
add address-pool=CCTV_POOL disabled=no interface=CCTV_VLAN name=CCTV_DHCP
add address-pool=WiFi_POOL disabled=no interface=WiFi_VLAN name=WiFi_DHCP
add address-pool=PPoE_POOL disabled=no interface=PPoE_VLAN name=PPoE_DHCP
add address-pool=MGMT_POOL disabled=no interface=MGMT_VLAN name=MGMT_DHCP
add bridge=BR1 frame-types=admit-only-vlan-tagged ingress-filtering=yes
interface=ether5
add bridge=BR1 interface=ether2 pvid=88
add bridge=BR1 interface=ether3 pvid=99
add bridge=BR1 interface=ether4 pvid=100
set discover-interface-list=BASE
/interface bridge vlan
add bridge=BR1 tagged=BR1,ether5 vlan-ids=10
add bridge=BR1 tagged=BR1,ether5 untagged=ether2 vlan-ids=88
add bridge=BR1 tagged=BR1,ether5 untagged=ether3 vlan-ids=99
add bridge=BR1 tagged=BR1,ether5 untagged=ether4 vlan-ids=100
add interface=ether1 list=WAN
add interface=MGMT_VLAN list=VLAN
add interface=CCTV_VLAN list=VLAN
add interface=PPoE_VLAN list=VLAN
add interface=MGMT_VLAN list=BASE
add address=192.168.99.1/24 interface=MGMT_VLAN network=192.168.99.0
add address=192.168.188.222/24 interface=ether1 network=192.168.188.0
add address=192.168.0.1/24 interface=CCTV_VLAN network=192.168.0.0
add address=192.168.100.1/24 interface=WiFi_VLAN network=192.168.100.0
add address=192.168.88.1/24 interface=PPoE_VLAN network=192.168.88.0
add address=192.168.0.0/24 dns-server=8.8.8.8 gateway=192.168.0.1
add address=192.168.88.0/24 dns-server=8.8.8.8 gateway=192.168.88.1
add address=192.168.99.0/24 dns-server=8.8.8.8 gateway=192.168.99.1
add address=192.168.100.0/24 dns-server=8.8.8.8 gateway=192.168.100.1
set allow-remote-requests=yes servers=8.8.8.8
add action=accept chain=input comment="Allow Estab & Related"
add action=accept chain=input comment="Allow VLAN" in-interface-list=VLAN
add action=accept chain=input comment="Allow MGMT_VLAN Full Access"
in-interface=MGMT_VLAN
add action=drop chain=input comment=Drop
add action=accept chain=forward connection-state=new dst-address=192.168.99.3
dst-port=443 log=yes protocol=tcp src-address-list=""
dst-port=22 log=yes protocol=tcp
add action=accept chain=forward comment="Allow Estab & Related"
add action=accept chain=forward comment="VLAN Internet Access only"
connection-state=new in-interface-list=VLAN out-interface-list=WAN
add action=drop chain=forward comment=Drop
add action=drop chain=forward comment="drop invalid connections"
connection-state=invalid protocol=tcp
add action=dst-nat chain=dstnat dst-port=4431 in-interface=ether1 log=yes
protocol=tcp to-addresses=192.168.99.3 to-ports=443
add action=dst-nat chain=dstnat dst-port=221 in-interface=ether1 protocol=tcp
add action=masquerade chain=srcnat comment="Default masquerade"
add distance=1 gateway=192.168.188.1
/system clock
set time-zone-name=Europe/Warsaw
/system identity
set name=Router
/tool mac-server
set allowed-interface-list=BASE
/tool mac-server mac-winbox
I think that I need to also make some order with WAN or ethernet1 port. I see in my config that sometime there is WAN sometime ethernet1. Could you advice how to resolve this problem too?
Regards
Slawek
