DNS Adlist match counter
What if I use two adlists, for example StevenBlack and r0xd4n3t, and the blocked address is in both lists at the same time - will the match counter increase for both lists?
Guessing at MT logic, it will hit first list and not second.
Incorrect.
I made two files, one with 3 domains, the other with 7 (including 3 domains from the first file). In case of a hit, the counter increases for both files.
Okay. It actually makes sense, when I think of it: all lists are consulted in parallel. Thanks for the info.
But how then do you know whether it makes sense to use a certain sheet, whether it will include a second one?
For example mine:
https://cdn.jsdelivr.net/gh/tarampampam/mikrotik-hosts-parser@master/.hosts/basic.txt
https://raw.githubusercontent.com/What-Zit-Tooya/Ad-Block/main/Main-Blocklist/Ad-Block-HOSTS.txt
https://justdomains.github.io/blocklists/lists/easyprivacy-justdomains.txt
https://justdomains.github.io/blocklists/lists/easylist-justdomains.txt
https://justdomains.github.io/blocklists/lists/adguarddns-justdomains.txt
https://justdomains.github.io/blocklists/lists/nocoin-justdomains.txt
https://raw.githubusercontent.com/StevenBlack/hosts/master/hosts
https://adaway.org/hosts.txt
https://pgl.yoyo.org/adservers/serverlist.php\?hostformat=hosts&showintro=0&mimetype=plaintext
https://raw.githubusercontent.com/hagezi/dns-blocklists/main/hosts/native.winoffice.txt
https://raw.githubusercontent.com/crazy-max/WindowsSpyBlocker/master/data/hosts/spy.txt
https://raw.githubusercontent.com/r0xd4n3t/pihole-adblock-lists/main/pihole_adlists.txt
https://raw.githubusercontent.com/badmojr/1Hosts/refs/heads/master/Xtra/domains.txt
And I found that pihole-adblock-lists includes StevenBlack.
