Ok, This is a strange one and hard to reproduce.
Symptom: PPPoE authentications are failing against our off site Radius server.
We can reboot the router and everything is fine again.
During investigation and while the router was in the state, I looked to see if there was a more current version of RouterOS and noticed that DNS would fail.
When I tried running
:put [resolve google.com] the result was Failure: dns server failure.
So I looked at the DNS settings
may/27/2019 11:54:34 by RouterOS 6.44.3
software id = Q018-HVJF
model = CCR1009-8G-1S
serial number = 5D920475E35E
set allow-remote-requests=yes cache-max-ttl=30m cache-size=32768KiB
max-concurrent-queries=2000 max-concurrent-tcp-sessions=1000
max-udp-packet-size=1024 servers=10.200.0.8,10.200.0.14
I added a third DNS server of 8.8.8.8 and that did not make any difference.
Next, I set allow-remote-requests=no
The DNS resolve now works.
Then I set allow-remote-requests=yes
The DNS resolve continued to work. But would fail again within about 30min
If I reboot the router, all is good for several days to a week.
This is occurring on several routers across our network randomly.
I’m confused as to why the initial reported problem was Radius Auth failures because Radius severs are using IPs not URL names to access our server.
I think this is some underlying issue that is manifesting itself in Radius operations as well as DNS operations.
Anybody see this?
