DNS assign for L2TP/IPSEC... bug?
Hi.
When i set DNS server (in PPP → Profiles) L2TP connection can’t be established. When i clear DNS server parameter then i can connect. Is it normal behavior?
In L2TP logs from router i can see that client in first case asked for ms-dns parameters and didn’t get it and then trying again multiple times and then stopped with error “No network protocols running”. In second case ms-dns parameter recieved router’s ip as ms-dns parameter and second ms-dns from IP → DNS.
So i can’t set my dns server in PPP profile. Is it normal behavior?
Here is screenshot with ConfReq/ConfAck/ConfRef
So i guess this is a bug. If i put two DNS servers in PPP profile than everything works OK. If one then no connection at all.
L2tp over IPsec will not be able to receive DNS suffix.
Yes, I know. Thank you.
The bug described here fixed in 6.30.2 firmware upgrade.
What’s new in 6.30.2 (2015-Jul-22 11:17):
*) pptp & l2tp - fixed problem where android client could not connect if
both dns names were not provided (was broken since v6.30);
