On my routers I normally use the isp’s dns servers. The way I do this is by checking “allow remote requests” under the dns setup. I do nothing else. It works. Is this the best way to do this?
This is enough for DNS configuration.
The only thing to be sure is that there is a forwarder dns configured.
If you use DHCP-client or pppoe then there could be an dns automatically.
Yeah… Set your clients to use your routers IP for DNS, set your router to allow remote DNS, block the DNS server from WAN things…
Unless you need a more full featured Bind9 or something this works well. If you need Bind9 functionality or DNSMasq or etc… then youll need to run that on another box.
Something particular you were trying to do? Or block ? or ?..
Eric I think that is what I am currently doing. What does that look like using command line so I can check it against my setup?
Post your export from filter, dhcp-server and dns and I can tell you.
Sent from my SCH-I545 using Tapatalk 4
if you have DNS set to providers DNS servers, then your router is still doing nothing (at best). If you have the default configuration left on the router you are fine, else, make sure nobody can connect from outside to your local DNS or your router could be used as DDoS tool.
Next is set up “/ip dns” servers and then point your PC to use your router to resolve domain names.
you can look up topics here on forums on how to secure your DNS service on the router, also, you can find general information about that on wiki.mikrotik.com
add address-pool=pool-local disabled=no interface=bridge-local name=local
add address-pool=pool-vlan1 disabled=no interface=bridge-vlan1 name=vlan1
add address-pool=pool-vlan2 disabled=no interface=bridge-vlan2 name=vlan2
set allow-remote-requests=yes
Just make sure under DHCP networks your set to use your routers IP as the DNS server… also ensure that somewhere in your firewall you are blocking port 53 via UDP and TCP from all the WAN interfaces. Otherwise seems correct.
Like this:
add address=192.168.1.0/24 dns-server=192.168.1.1 gateway=192.168.1.1
add address=192.168.2.0/24 dns-server=192.168.2.1 gateway=192.168.2.1
add address=192.168.3.0/24 dns-server=192.168.3.1 gateway=192.168.3.1and then have a default drop rule in the firewall?
Yeah. That should work.
actually, if you have DNS servers set up in “/ip dns” you can leave DNS server field empty in dhcp-server setup.
Which will it use? Itself or the listed servers?
it sends itself and from the configured.
for example, I had 8.8.8.8 set as DNS server and i got was 192.168.88.1 and 8.8.8.8
Hmm… cool. Thanks for the info.
