MikroTik RouterOS 7.21.3 (c) 1999-2026 https://www.mikrotik.com/
Press F1 for help
[XXXX] > export
2026-02-24 18:11:36 by RouterOS 7.21.3
software id = ID ID ID
model = RB5009UG+S+
serial number = Serial
add frame-types=admit-only-vlan-tagged name=BR1 port-cost-mode=short protocol-mode=none vlan-filtering=yes
set [ find default-name=ether1 ] l2mtu=1514
set [ find default-name=ether2 ] l2mtu=1514
set [ find default-name=ether3 ] l2mtu=1514
set [ find default-name=ether4 ] l2mtu=1514
set [ find default-name=ether5 ] l2mtu=1514
set [ find default-name=ether6 ] l2mtu=1514
set [ find default-name=ether7 ] l2mtu=1514
set [ find default-name=ether8 ] l2mtu=1514
set [ find default-name=sfp-sfpplus1 ] l2mtu=1514
/interface vlan
add interface=BR1 name=2.4Ghz_VLAN vlan-id=77
add interface=BR1 name=LAITE_VLAN vlan-id=75
add interface=BR1 name=M_LAPTOP_VLAN vlan-id=30
add interface=BR1 name=OMALAPTOP_VLAN vlan-id=40
add interface=BR1 name=OMA_PC_VLAN vlan-id=20
add interface=BR1 name=PI_VLAN vlan-id=50
add interface=BR1 name=SFP_VLAN vlan-id=25
add interface=BR1 name=SSID1_VLAN vlan-id=60
add interface=BR1 name=SSID2_VLAN vlan-id=65
add interface=BR1 name=TV_VLAN vlan-id=70
add name=WAN
add name=LAN
add name=MGMT
/interface lte apn
set [ find default=yes ] name=Handset use-network-apn=no
add name=OMA_PC_POOL ranges=10.0.20.55-10.20.0.56
add name=M_LAPTOP_POOL ranges=10.0.30.10-10.0.30.15
add name=OMALAPTOP_POOL ranges=10.0.40.10-10.0.40.15
add name=PI_POOL ranges=10.0.50.10-10.0.50.15
add name=SSID1_POOL ranges=10.0.60.10-10.0.60.15
add name=TV_POOL ranges=10.0.70.10-10.0.70.15
add name=SSID2_POOL ranges=10.0.65.10-10.0.65.15
add name=dhcp_pool8 ranges=100.64.0.1-100.64.81.166,100.64.81.168-100.64.255.254
add name=LAITE_POOL ranges=10.0.75.10-10.0.75.15
add name=2.4Ghz_POOL ranges=10.0.77.10-10.0.77.15
add name=SFP_POOL ranges=10.0.25.10-10.0.25.15
add address-pool=OMA_PC_POOL interface=OMA_PC_VLAN lease-time=10m name=OMA_PC_DHCP
add address-pool=M_LAPTOP_POOL interface=M_LAPTOP_VLAN lease-time=10m name=M_LAPTOP_DHCP
add address-pool=OMALAPTOP_POOL interface=OMALAPTOP_VLAN lease-time=10m name=OMALAPTOP_DHCP
add address-pool=PI_POOL interface=PI_VLAN lease-time=10m name=PI_DHCP
add address-pool=SSID1_POOL interface=SSID1_VLAN lease-time=10m name=SSID1_DHCP
add address-pool=TV_POOL interface=TV_VLAN lease-time=521w3d name=TV_DHCP
add address-pool=SSID2_POOL interface=SSID2_VLAN lease-time=10m name=SSID2_DHCP
add address-pool=dhcp_pool8 interface=ether1 name=dhcp1
add address-pool=LAITE_POOL interface=LAITE_VLAN lease-time=521w3d name=LAITE_DHCP
add address-pool=2.4Ghz_POOL interface=2.4Ghz_VLAN lease-time=10m name=2.4Ghz_DHCP
add address-pool=SFP_POOL interface=SFP_VLAN lease-time=10m name=SFP_DHCP
/ip smb users
add bridge=BR1 frame-types=admit-only-untagged-and-priority-tagged interface=ether2 internal-path-cost=10 path-cost=10 pvid=20
add bridge=BR1 frame-types=admit-only-untagged-and-priority-tagged interface=ether3 internal-path-cost=10 path-cost=10 pvid=30
add bridge=BR1 frame-types=admit-only-untagged-and-priority-tagged interface=ether4 internal-path-cost=10 path-cost=10 pvid=40
add bridge=BR1 frame-types=admit-only-untagged-and-priority-tagged interface=ether5 internal-path-cost=10 path-cost=10 pvid=50
add bridge=BR1 frame-types=admit-only-untagged-and-priority-tagged interface=ether7 internal-path-cost=10 path-cost=10 pvid=70
add bridge=BR1 frame-types=admit-only-vlan-tagged interface=ether6 internal-path-cost=10 path-cost=10 pvid=60
add bridge=BR1 frame-types=admit-only-untagged-and-priority-tagged interface=sfp-sfpplus1 pvid=25
set loose-tcp-tracking=no tcp-established-timeout=30m udp-timeout=10s
set discover-interface-list=none
/ip settings
set max-neighbor-entries=4096 rp-filter=strict
/ipv6 settings
set disable-ipv6=yes
/interface bridge vlan
add bridge=BR1 tagged=BR1,ether6 untagged=ether2 vlan-ids=20
add bridge=BR1 tagged=BR1 vlan-ids=30
add bridge=BR1 tagged=BR1 vlan-ids=40
add bridge=BR1 tagged=BR1 vlan-ids=50
add bridge=BR1 tagged=BR1,ether6 vlan-ids=60,65,75,77
add bridge=BR1 tagged=BR1 vlan-ids=70
add bridge=BR1 tagged=BR1 vlan-ids=25
add interface=ether1 list=WAN
add interface=OMA_PC_VLAN list=LAN
add interface=M_LAPTOP_VLAN list=LAN
add interface=OMALAPTOP_VLAN list=LAN
add interface=PI_VLAN list=LAN
add interface=ether8 list=MGMT
add interface=SSID1_VLAN list=LAN
add interface=TV_VLAN list=LAN
add interface=*12 list=WAN
add interface=SSID2_VLAN list=LAN
add interface=OMA_PC_VLAN list=MGMT
add interface=LAITE_VLAN list=LAN
add interface=2.4Ghz_VLAN list=LAN
add interface=SFP_VLAN list=LAN
/interface ovpn-server server
add auth=sha1,md5 mac-address=xx:xx:xx:xx name=ovpn-server1
add address=10.0.20.1/24 interface=OMA_PC_VLAN network=10.0.20.0
add address=10.0.30.1/24 interface=M_LAPTOP_VLAN network=10.0.30.0
add address=10.0.40.1/24 interface=OMALAPTOP_VLAN network=10.0.40.0
add address=10.0.50.1/24 interface=PI_VLAN network=10.0.50.0
add address=10.0.60.1/24 interface=SSID1_VLAN network=10.0.60.0
add address=10.0.70.1/24 interface=TV_VLAN network=10.0.70.0
add address=10.0.80.1/24 interface=ether8 network=10.0.80.0
add address=10.0.65.1/24 interface=SSID2_VLAN network=10.0.65.0
add address=10.0.75.1/24 interface=LAITE_VLAN network=10.0.75.0
add address=10.0.77.1/24 interface=2.4Ghz_VLAN network=10.0.77.0
add address=10.0.25.1/24 interface=SFP_VLAN network=10.0.25.0
/ip cloud
set update-time=no
/ip dhcp-client
/ip dhcp-server lease
add address=xxx.xxx.xxx.xxx client-id=xx:xx:xx: mac-address=xx:xx:xx:xx server=SFP_DHCP
add address=10.0.20.0/24 dns-server=1.1.1.2,1.0.0.2 gateway=10.0.20.1
add address=10.0.25.0/24 dns-server=1.1.1.2,1.0.0.2 gateway=10.0.25.1
add address=10.0.30.0/24 dns-server=1.1.1.2,1.0.0.2 gateway=10.0.30.1
add address=10.0.40.0/24 dns-server=1.1.1.2,1.0.0.2 gateway=10.0.40.1
add address=10.0.50.0/24 dns-server=1.1.1.2,1.0.0.2 gateway=10.0.50.1
add address=10.0.60.0/24 dns-server=1.1.1.2,1.0.0.2 gateway=10.0.60.1
add address=10.0.65.0/24 dns-server=1.1.1.2,1.0.0.2 gateway=10.0.65.1
add address=10.0.70.0/24 dns-server=1.1.1.2,1.0.0.2 gateway=10.0.70.1
add address=10.0.75.0/24 dns-server=1.1.1.2,1.0.0.2 gateway=10.0.75.1 netmask=24
add address=10.0.77.0/24 dns-server=1.1.1.2,1.0.0.2 gateway=10.0.77.1
add address=XXX.XXX.XXX.XXX gateway=xxx.xxx.xxx.xxx
set cache-max-ttl=30m servers=1.1.1.2,1.0.0.2
/ip firewall address-list
add address=10.0.20.0/24 list=Local_LAN
add address=10.0.25.0/24 list=Local_LAN
add address=10.0.30.0/24 list=Local_LAN
add address=10.0.40.0/24 list=Local_LAN
add address=10.0.50.0/24 list=Local_LAN
add address=10.0.60.0/24 list=Local_LAN
add address=10.0.65.0/24 list=Local_LAN
add address=10.0.70.0/24 list=Local_LAN
add address=10.0.75.0/24 list=Local_LAN
add address=10.0.77.0/24 list=Local_LAN
add address=127.0.0.0/8 comment="defconf: RFC6890" list=bad_ipv4
add address=192.0.0.0/24 comment="defconf: RFC6890" list=bad_ipv4
add address=192.0.2.0/24 comment="defconf: RFC6890 documentation" list=bad_ipv4
add address=198.51.100.0/24 comment="defconf: RFC6890 documentation" list=bad_ipv4
add address=203.0.113.0/24 comment="defconf: RFC6890 documentation" list=bad_ipv4
add address=0.0.0.0/8 comment="defconf: RFC6890" list=not_global_ipv4
add address=100.64.0.0/10 comment="defconf: RFC6890" list=not_global_ipv4
add address=169.254.0.0/16 comment="defconf: RFC6890" list=not_global_ipv4
add address=172.16.0.0/12 comment="defconf: RFC6890" list=not_global_ipv4
add address=192.0.0.0/29 comment="defconf: RFC6890" list=not_global_ipv4
add address=192.168.0.0/16 comment="defconf: RFC6890" list=not_global_ipv4
add address=198.18.0.0/15 comment="defconf: RFC6890 benchmark" list=not_global_ipv4
add address=255.255.255.255 comment="defconf: RFC6890" list=not_global_ipv4
add address=224.0.0.0/4 comment="defconf: multicast" list=bad_src_ipv4
add address=255.255.255.255 comment="defconf: RFC6890" list=bad_src_ipv4
add address=0.0.0.0/8 comment="defconf: RFC6890" list=bad_dst_ipv4
add address=224.0.0.0/4 comment="defconf: RFC6890" list=bad_dst_ipv4
add address=10.0.80.0/24 list=Local_LAN
add action=drop chain=input comment="\"Drop invalid\"" connection-state=invalid log-prefix=Input_Drop_Invalid_
add action=accept chain=input comment="\"Accept established, related\"" connection-state=established,related
add action=drop chain=input comment="\"Drop All from WAN\"" in-interface-list=WAN log-prefix=Drop_Wan
add action=accept chain=input comment="\"Accept ICMP\"" protocol=icmp
add action=accept chain=input comment="Accept to local loopback." dst-address=127.0.0.1 in-interface=lo src-address=127.0.0.1
add action=accept chain=input comment="Allow 5009 config from port 8" in-interface-list=MGMT src-address=10.0.80.5
add action=accept chain=input comment="Allow 5009 config from port 2" in-interface-list=MGMT src-address=10.0.20.55
add action=drop chain=input comment="\"Drop all else\"" log-prefix=Input_Drop_All_Else_
add action=drop chain=forward comment="\"Drop invalid\"" connection-state=invalid log-prefix=Forward_Drop_Invalid_
add action=accept chain=forward comment="\"Accept established, related\"" connection-state=established,related
add action=drop chain=forward comment="\"Drop all from WAN not DSTNATed\"" connection-nat-state=!dstnat connection-state=new in-interface-list=WAN
add action=accept chain=forward comment="Allow list LAN to internet" in-interface-list=LAN out-interface-list=WAN
add action=accept chain=forward comment="Allow Zyxel config from port 2" dst-address=10.0.20.15 src-address=10.0.20.55
add action=accept chain=forward comment="Allow Zyxel config from port 8" dst-address=10.0.20.15 src-address=10.0.80.5
add action=accept chain=forward comment="Allow Shelly config from port 2" dst-address=10.0.75.15 src-address=10.0.20.55
add action=drop chain=forward comment="\"Drop all else\"" log=yes log-prefix=Forward_Drop_All_Else_
add action=masquerade chain=srcnat comment="\"NAT\"" out-interface-list=WAN
/ip firewall raw
add action=accept chain=prerouting comment="\"defconf: enable for transparent firewall\"" disabled=yes
add action=drop chain=prerouting comment="\"defconf: drop forward to local lan from WAN\"" dst-address-list=Local_LAN in-interface-list=WAN
add action=drop chain=prerouting comment="\"defconf: drop bogon IP's\"" src-address-list=bad_ipv4
add action=drop chain=prerouting comment="\"defconf: drop bogon IP's\"" dst-address-list=bad_ipv4
add action=drop chain=prerouting comment="\"defconf: drop bogon IP's\"" src-address-list=bad_src_ipv4
add action=drop chain=prerouting comment="\"defconf: drop bogon IP's\"" dst-address-list=bad_dst_ipv4 log-prefix="Drop bogon ips"
add action=drop chain=prerouting comment="\"defconf: drop non global from WAN\"" in-interface-list=WAN src-address-list=not_global_ipv4
/ip firewall service-port
set ftp disabled=yes
set tftp disabled=yes
set h323 disabled=yes
set sip disabled=yes
set pptp disabled=yes
/ip ipsec profile
/ip service
set ssh disabled=yes
set telnet disabled=yes
set www disabled=yes
set www-ssl tls-version=only-1.2
set winbox address=10.0.80.0/24,10.0.20.55/32
set api disabled=yes
set api-ssl disabled=yes
/ip ssh
set strong-crypto=yes
/ipv6 firewall filter
add action=drop chain=output
/ipv6 nd
set [ find default=yes ] advertise-dns=yes
/system clock
set time-zone-autodetect=no time-zone-name=Europe/Helsinki
/system identity
set name=XXX
/system logging
add disabled=yes topics=ntp
/system note
set show-at-login=no
/system ntp client
set enabled=yes
/system ntp client servers
add address=194.100.49.139
add address=194.100.49.151
/system routerboard reset-button
set enabled=yes
/system scheduler
add disabled=yes interval=1d name="Wan Off" on-event="/interface disable [find where default-name=\"ether1\"]\r\
\n" policy=ftp,reboot,read,write,policy,test,password,sniff,sensitive,romon start-date=2023-12-26 start-time=22:00:00
add disabled=yes interval=1d name="Wan On" on-event="/interface enable [find where default-name=\"ether1\"]\r\
\n" policy=ftp,reboot,read,write,policy,test,password,sniff,sensitive,romon start-date=2023-12-27 start-time=04:00:00
add interval=1d name="TV-Box interface OFF" on-event="/interface disable [find where default-name=\"ether7\"]" policy=ftp,reboot,read,write,policy,test,password,sniff,sensitive,romon start-date=2025-05-31 start-time=21:25:00
add interval=1d name="TV-Box interface ON" on-event="/interface enable [find where default-name=\"ether7\"]" policy=ftp,reboot,read,write,policy,test,password,sniff,sensitive,romon start-date=2025-06-01 start-time=06:00:00
/tool bandwidth-server
set enabled=no
/tool mac-server
/tool mac-server mac-winbox
set allowed-interface-list=MGMT
/tool mac-server ping
set enabled=no
/user settings
set minimum-password-length=15
[XXXXXX] >
