Thanks.
Even after flush cache?
Do you see any other issue on my config?
# dec/13/2019 15:00:36 by RouterOS 6.43.4
# software id = 5HTH-KXRN
# model = RouterBOARD 750 r2
# serial number = 67D206662025
add fast-forward=no name=Bdg-Local
set [ find default-name=ether1 ] name=eth1-Intervel
set [ find default-name=ether2 ] name=eth2-Speedy
set [ find default-name=ether3 ] name=ether3-BDG
set [ find default-name=ether4 ] name=ether4-BDG
set [ find default-name=ether5 ] name=ether5-BDG
/interface pppoe-client
add disabled=no interface=eth1-Intervel name=pppoe-intervel password=137agrv \
user=moinho.hotel
add name=Internet
/ip firewall layer7-protocol
add name=facebook regexp=facebook
/ip hotspot profile
add name=pool1 ranges=192.168.1.128-192.168.1.254
add address-pool=pool1 disabled=no interface=Bdg-Local name=DHCP-Local
/queue simple
add name=ADM priority=1/1 target=192.168.1.0/25
add name=WIFI target=192.168.1.128/25
add bridge=Bdg-Local interface=ether3-BDG
add bridge=Bdg-Local interface=ether4-BDG
add bridge=Bdg-Local interface=ether5-BDG
add interface=pppoe-intervel list=Internet
add interface=eth2-Speedy list=Internet
add address=192.168.3.2/24 interface=eth2-Speedy network=192.168.3.0
add address=192.168.1.1/24 interface=Bdg-Local network=192.168.1.0
/ip cloud
set ddns-enabled=yes
/ip dhcp-server lease
add address=192.168.1.11 client-id=1:e0:d5:5e:37:91:6c mac-address=\
E0:D5:5E:37:91:6C server=DHCP-Local
add address=192.168.1.30 client-id=1:8c:dc:d4:fe:e8:13 mac-address=\
8C:DC:D4:FE:E8:13 server=DHCP-Local
add address=192.168.1.0/24 dns-server=192.168.1.1 gateway=192.168.1.1
set allow-remote-requests=yes cache-max-ttl=1d servers=\
8.8.8.8,208.67.222.222,84.200.69.80
# inactive time
Bloqueio-Facebook-PC-Recepcao-16:30h-23:59h dst-port=80,443 \
layer7-protocol=facebook protocol=tcp src-address=192.168.1.11 time=\
16h30m-23h59m50s,sun,mon,tue,wed,thu,fri,sat
# inactive time
add action=drop chain=forward comment=Bloqueio-Facebook-PC-Recepcao-00h-07h \
dst-port=80,443 layer7-protocol=facebook protocol=tcp src-address=\
192.168.1.11 time=0s-7h,sun,mon,tue,wed,thu,fri,sat
# inactive time
"Bloqueio Facebook - Recepcao - 7h-16:29 - Valter-Quarta-Feira" dst-port=\
80,443 layer7-protocol=facebook protocol=tcp src-address=192.168.1.11 \
time=7h5s-16h29m55s,thu
# inactive time
add action=accept chain=output comment=\
webproxy-libera-porta-8080-16:30h-23:59h dst-port=8080 protocol=tcp time=\
16h30m-23h59m59s,sun,mon,tue,wed,thu,fri,sat
# inactive time
add action=accept chain=output comment=webproxy-libera-porta-8080-00h-07h \
dst-port=8080 protocol=tcp time=0s-7h,sun,mon,tue,wed,thu,fri,sat
# inactive time
webproxy-libera-porta-8080-7h-16:29h-Folga-Valter-Quinta-Feira dst-port=\
8080 protocol=tcp time=7h5s-16h29m55s,thu
/ip firewall mangle
add action=mark-routing chain=prerouting new-routing-mark=rede-adm \
passthrough=yes src-address=192.168.1.0/25
add action=mark-routing chain=prerouting new-routing-mark=rede-wifi \
passthrough=yes src-address=192.168.1.128/25
passthrough=yes src-address=192.168.1.15
add action=mark-connection chain=input comment=\
"Entra Intervel regra mark connection " in-interface=pppoe-intervel \
new-connection-mark=intervel passthrough=yes
"Entra speedy regra mark connection " in-interface=eth2-Speedy \
new-connection-mark=speedy passthrough=yes
add action=mark-routing chain=output comment=\
"Sai Intervel regra mark connection " connection-mark=intervel \
new-routing-mark=intervel passthrough=yes
"Sai Speedy regra mark connection " connection-mark=speedy \
new-routing-mark=speedy passthrough=yes
add action=dst-nat chain=dstnat dst-port=9070 in-interface=pppoe-intervel \
protocol=tcp to-addresses=192.168.1.15 to-ports=9070
add action=dst-nat chain=dstnat dst-port=2101 in-interface=pppoe-intervel \
protocol=tcp to-addresses=192.168.1.15 to-ports=2101
# inactive time
add action=redirect chain=dstnat comment=\
Redirecionamento-webproxy-porta-8080-16:30h-23:59h dst-port=80 protocol=\
16h30m-23h59m50s,sun,mon,tue,wed,thu,fri,sat to-ports=8080
# inactive time
Redirecionamento-webproxy-porta-8080-00h-07h dst-port=80 protocol=tcp \
time=0s-7h,sun,mon,tue,wed,thu,fri,sat to-ports=8080
# inactive time
Redirecionamento-webproxy-porta-8080-7h-16:29h-Folga-Valter-Quinta-Feira \
dst-port=80 protocol=tcp time=7h5s-16h29m55s,thu to-ports=8080
/ip firewall raw
add action=drop chain=prerouting dst-port=53 in-interface-list=Internet \
protocol=tcp
protocol=udp
/ip proxy
set enabled=yes max-fresh-time=1d
/ip proxy access
add dst-host=:deezer src-address=192.168.1.11
add dst-host=:webmail|locaweb|webmail-seguro.com.br src-address=192.168.1.11
add dst-host=:ventana src-address=192.168.1.11
add dst-host=:trivago src-address=192.168.1.11
add dst-host=:tripadvisor src-address=192.168.1.11
add dst-host=:sabesp src-address=192.168.1.11
add dst-host=:pousadavillaggioitalia src-address=192.168.1.11
add dst-host=:pousadaitaliaeleganza src-address=192.168.1.11
add dst-host=:omnibees src-address=192.168.1.11
add dst-host=:nfecj src-address=192.168.1.11
add dst-host=:nfe.fazenda src-address=192.168.1.11
add dst-host=:myhotel.omnibees src-address=192.168.1.11
add dst-host=:meuip src-address=192.168.1.11
add dst-host=:java src-address=192.168.1.11
add dst-host=:hotelmoinhoitalia src-address=192.168.1.11
add dst-host=:hoteis src-address=192.168.1.11
add dst-host=:fusionti src-address=192.168.1.11
add dst-host=:fazenda src-address=192.168.1.11
add dst-host=:extranet.decolar src-address=192.168.1.11
add dst-host=:correios src-address=192.168.1.11
add dst-host=:camposdojordao src-address=192.168.1.11
add dst-host=:booking src-address=192.168.1.11
add dst-host=:gruppoitalia src-address=192.168.1.11
add dst-host=:globo src-address=192.168.1.11
add dst-host=:focoaprendizagem src-address=192.168.1.11
add dst-host=:educacao.sp src-address=192.168.1.11
add dst-host=:escoladeformacao.sp src-address=192.168.1.11
add dst-host=:inovaeducacao.escoladeformacao.sp src-address=192.168.1.11
add dst-host=192.168.3.1 src-address=192.168.1.11
add action=deny redirect-to=www.fusionti.info/negado src-address=192.168.1.11
add comment=Rota-Adm2 distance=2 gateway=pppoe-intervel routing-mark=rede-adm
add comment=Rota-Adm1 disabled=yes distance=1 gateway=192.168.3.1 \
add comment=Intervel-Italia distance=1 dst-address=138.94.71.230/32 gateway=\
add comment=Rota-Wifi1 distance=1 gateway=pppoe-intervel routing-mark=\
rede-wifi
add comment="Regra Entrada e Saida Intervel regra mark connection " distance=\
1 gateway=pppoe-intervel routing-mark=intervel
add comment="Regra Entrada e Saida Speedy regra mark connection " distance=1 \
gateway=192.168.3.1 routing-mark=speedy
add distance=1 gateway=192.168.3.1
add distance=1 gateway=pppoe-intervel
add comment=Check-Speedy distance=1 dst-address=189.8.2.162/32 gateway=\
192.168.3.1 pref-src=192.168.3.1
/ip service
set telnet disabled=yes
set ftp disabled=yes
set www disabled=yes
set ssh disabled=yes
set api disabled=yes
set api-ssl disabled=yes
/system clock
set time-zone-autodetect=no time-zone-name=America/Sao_Paulo
/system ntp client
set enabled=yes primary-ntp=200.160.0.8 secondary-ntp=200.189.40.8
/system routerboard settings
set silent-boot=no
/tool netwatch
add disabled=yes down-script=\
"/ip route set [/ip route find comment=Rota-Adm1] disabled=yes" host=\
189.8.2.162 interval=30s up-script=\
"ip route set [/ip route find comment=Rota-Adm1] disabled=no"
