DNS defaults to router gateway
Hi, I have a situation where I’m supposed to get DNS via DHCP, but the primary DNS I receive when a I do “ipconfig /all” is the local router gateway (IP of the router). So, I kept the default local IPs, and my DNS shows as “192.168.88.1”. When I do a “ipconfig /all” I get the primary (first listed) DNS as 192.168.88.1. The dynamic DNS servers are correct (first one is Google DNS 8.8.8.:sunglasses:.
I went to the “WebFig” tab, and Went to “IP → DNS” and noticed the “Dynamic Servers” are correct. I even hit the up arrow and made the “Servers” entries disappear, and hit “apply” and the default DNS (after I disconnected to the Wifi Network on the router, and reconnected) still shows the DNS as my local gateway. I checked the Wifi Adapter, and there’s no hard coded DNS. Any ideas? I really like the way you can manage everything on this. I can’t use it right now, as anything (which makes sense) says DNS error.
IP>DHCP-SERVER>NETWORKS
Click into your network and then use the DNS box to full in the DNS servers you want to hand to DHCP clients.
That should work, do an ipconfig release and renew just in case.
