I’m new a RouterOS scripting, so I need some help to understand a problem.
I’m using a script from
http://wiki.mikrotik.com/wiki/Setting_static_DNS_record_for_each_DHCP_lease
to create DNS entries for each DHCP lease.
the script:
:local zone "dhcp";
:local ttl "00:05:00"
:local hostname
:local ip
:local dnsip
:local dhcpip
:local dnsnode
:local dhcpnode
/ip dns static;
:foreach i in=[find where name ~ (".*\\.".$zone) ] do={
:set hostname [ get $i name ];
:set hostname [ :pick $hostname 0 ( [ :len $hostname ] - ( [ :len $zone ] + 1 ) ) ];
/ip dhcp-server lease;
:set dhcpnode [ find where host-name=$hostname ];
:if ( [ :len $dhcpnode ] > 0) do={
:log debug ("Lease for ".$hostname." still exists. Not deleting.");
} else={
# there's no lease by that name. Maybe this mac has a static name.
:local found false
/system script environment
:foreach n in=[ find where name ~ "shost[0-9A-F]+" ] do={
:if ( [ get $n value ] = $hostname ) do={
:set found true;
:if ( found ) do={
:log debug ("Hostname ".$hostname." is static");
} else={
:log info ("Lease expired for ".$hostname.", deleting DNS entry.");
/ip dns static remove $i;
:foreach i in=[find] do={
:set hostname ""
:local mac
:set dhcpip [ get $i address ];
:set mac [ get $i mac-address ];
:while ($mac ~ ":") do={
:local pos [ :find $mac ":" ];
:set mac ( [ :pick $mac 0 $pos ] . [ :pick $mac ($pos + 1) 999 ] );
:foreach n in=[ /system script environment find where name=("shost" . $mac) ] do={
:set hostname [ /system script environment get $n value ];
:if ( [ :len $hostname ] = 0) do={
:set hostname [ get $i host-name ];
:if ( [ :len $hostname ] > 0) do={
:set hostname ( $hostname . "." . $zone );
/ip dns static;
:set dnsnode [ find where name=$hostname ];
:if ( [ :len $dnsnode ] > 0 ) do={
# it exists. Is its IP the same?
:set dnsip [ get $dnsnode address ];
:if ( $dnsip = $dhcpip ) do={
:log debug ("DNS entry for " . $hostname . " does not need updating.");
} else={
:log info ("Replacing DNS entry for " . $hostname);
/ip dns static remove $dnsnode;
/ip dns static add name=$hostname address=$dhcpip ttl=$ttl;
} else={
# it doesn't exist. Add it
:log info ("Adding new DNS entry for " . $hostname);
and named it syncdnsdhcp with policy rights “read,write”
If I run it from CLI it works as expected.
If I run it from the Webinterface I got an error:
script, error script: not enough permissions (9)
So I tried to create a scheduler to run this script ervery 5 min.
system scheduler add name=syncdnsdhcp on-event=syncdhcpdns start-time=00:00:00 start-date=jan/01/2017 interval=00:05:00 policy=read,write disable=no
the result: the script dosn’t run and every 5 minutes I got an error in my log
What have I done wrong?
Why does it ran from CLI but not from Webinterface?
Why does the scheduler not work?
RouterOS V6.38.1(stable)
Tested on a 2011-UiAS and a 2011-UiAS-2Hnd
Thank you.
David from Germany
