DNS does not cache in 5.24
Hey Guys..
i have upgrade to 5.24 but the dns server in ip/dns/cache does not cache any content!!
Waiting for your reply..
Thx guys
It was working fine for me.
Ae you sure you have it setup correctly?
Yes ..
ip/dns/ servers, and i have put the server addresses, and in ppp/profiles i have put there also Ip of the Dns.
Let me know pls if there is something missing!!
Thx.
Have you told it to accept remote connections?
DNS Cache works fine in 5.24 - maybe you can post your setup config ?
Thx for the reply..
here is my settings:
[admin@Swift] /ip dns> print
servers: 10.249.209.101,10.249.209.102
dynamic-servers:
allow-remote-requests: yes
max-udp-packet-size: 8192
cache-size: 8192KiB
cache-max-ttl: 1w
cache-used: 12KiB
STILL DNS CACHE IS EMPTY!
Are you sure that clients are using the routerboard as their DNS Server? The cache will only show entries if either the router itself successfully requests a lookup.
I’m using the Dns giving by my isp!
Can u help on how to do this.. all my clients are pppoe clients
I suggest that you upload output from /export compact so we can get a better idea what the config is. You can specify the DNS server in the PPPoE profile for the clients. At the moment I suspect that your clients are using the ISP DNS servers or other servers directly thus you don’t have any requests hitting the RouterOS DNS server.
I agree with Celtic, it would be best to post /export compact
You can force all DNS traffic to be redirected to the router using NAT.
add action=redirect chain=dstnat dst-port=53 protocol=udp to-ports=53
add action=redirect chain=dstnat dst-port=53 protocol=tcp to-ports=53
Thx guys a lot…
I have solved it.. the problem was with local address in pppoe clients, it was blank before, once i added it with the dns address in ppp/profiles caching start to cache…
Thx again for your time :slight_smile:
