Cheers.
How can I block pronographic pages using DNs DoH, I would appreciate if someone can help me.
El DONCITO.
Cheers.
El DONCITO.
You can only block pornographic sites.
The problem is, DoH seems to be invented to able you to visit pornographic sites and no one can stop you doing so.
Well let me tell you dear friend that it can be done and I already did it.
If you already did, then why are you asking?
TBH, I agree with @msatter, because If someone wants to stop me from visiting porn, they would have to physically cut the cable, otherwise I will find a way.
I try to block it by IP address but then you are always on the backfoot. Looking at the size of packets is void by adding padding. SNI is in the future not possible anymore.
It be become easier for collecting user behavior by the big firms.
Cheers.
How can I block pronographic pages using DNs DoH, I would appreciate if someone can help me.El DONCITO.
using cloudflare gateway
or using 1.1.1.3 and 1.0.0.3 dns
Sent from my SM-A705FN using Tapatalk
inetnum: 1.1.1.0 - 1.1.1.255 + 1.0.0.0-1.0.0.255
netname: APNIC-LABS
descr: APNIC and Cloudflare DNS Resolver project
Adding 1.1.1.0/24 and 1.0.0.0/24 to the Rouge DNS address-list
