DNS failure on ais.channel4.com
I’ve got a problem with my router board (RB2011L running v5.14).
I have been unable to watch catchup TV on Channel 4 here in the UK. The specific URL I’ve been using is ‘ps3.channel4.com’.
Using Wireshark I have tracked this down to a DNS problem. If using the router board DNS server the following domain name does not resolve ‘ais.channel4.com’.
Using Wireshark on the LAN side I can see that the client is sending a DNS request and the routerboard is responding to say there is no such domain.
If however I monitor the WAN side I can see the routerboard issuing the same request to my ISP DNS server and that server replying to the rouerboard with the correct information. - for some reason the routerboard is not relying to the original client with the information provided from the ISP server.
I have also tried using the ‘resolve ais.channel4.com’ on cli. This responds with ‘failure: dns server failure’
As a workaround I have added the ISP DNS server entry to the DHCP config which allows all lan hosts to resolve the URL.
I would be interested if any one has any thoughts on what the underlying issue is here?
Many Thanks
Open terminal and issue the following command:
/ip dns set max-udp-packet-size=4096
See if you can resolve that domain then. If it didn’t work, upgrade RouterOS to the latest stable version (v5.24 at the time of writing) . There had been some issues with DNS resolving that’s been fixed.
If you still had that problem after following those steps, report back.
Devil,
Thank you very much! All working now!
For the record - max-udp-packet-size was already at 4096 so I went ahead and updated to the latest (5.24) firmware which has sorted it out.
Thanks again
