Get rid of the DDOs blocking, its clearly getting in the way of your configuration for DNS purposes and it is not required.
If your ISP is not capable of blocking DDOS then you are wasting your time trying to do it on the MT.
Stick to the basic default firewall rules for troublefree traffic for your network.
As the very first rule in both input and forward chains of /ip firewall filter, place a rule connection-state=established,related action=accept. This will make all the other rules handle only the initial packet of each new logical connection, and if one of those other rules accepts such an initial packet, the rest of packets belonging to that same logical connection will be let through by the “accept established or related” one. So DNS responses will not be treated as a DDoS attack any more, and your router’s CPU will sweat much less as it will not have to push every single packet through the complete list of rules.
Also, the rule to accept incoming connections to port 53 must be placed before those DDoS protection ones, and must not accept packets coming from WAN.
The only part that confuses me is having the WAN part of your bridge? besides the fact its coming from a switch LOL. The rest of the config is far too complex for me to comment. ( Chapter 14 MTUNA certification states, if you know you are above your head, don’t drown just remove yourself from the situation )
