Hi guys!
I’m setting up an IPTV app at location with core being Mikrotik CCR.
The app by default pulls the channel playlist from address:
http://iptv.local/playlist.m3u
So to make it work I set up static DNS rule in CCR like this:
/ip dns static
add address=xxx.yyy.xx.qqq name=iptv.local
and uploaded the “playlist.m3u” to the root directory of xxx.yyy.xx.qqq. This works great as expected.
The problem is I’m doing next location that will need a different playlist.
I can’t make any changes in the app with a link or file name.
I also can’t make subdirectories since in DNS I can only put an IP address.
Is there any way to solve it without creating separate servers for each playlist?
