DNS FWD entry not working as expected
When I set a static DNS entry:
name="example.com" type=A address=10.10.10.10 ttl=1d match-subdomain=yes
Then I verify:
:put [:resolve domain-name=test.example.com]`
10.10.10.10
All good.
But when I use a FWD-entry, because I want some other nameserver to handle a specific domain, it does not work:
name="example.com" type=FWD forward-to=10.23.45.10 ttl=1d match-subdomain=yes
It returns:
:put [:resolve domain-name=foo.example.com]
failure: dns name does not exist
But to verify, when I use resolve with explicit server param it resolves perfectly.
 :put [:resolve domain-name=foo.example.com server=10.23.45.10]
10.23.45.16
Is this a ROS bug or does FWD just not work how I would assume it works?
ROS: 7.8
Did you just forget to mention that you use DoH?
Yes, I did not mention that. I have configured a DoH server.
Didn’t you wonder how I knew that without a doubt?
I also assume you have NOT read the online help.
If you read the help, you’d instantly understand how I knew you were using DoH…
On synthesis, your FWD point to one DNS without certificate issued by one global CA, and, if you use the DoH, the FWD field make no sense.
Sry, just found that. DNS - RouterOS - MikroTik Documentation
DoH is not compatible with FWD-type static entries, in order to utilize FWD entries, DoH must not be configured.
I do read the online help. But sometimes important infos are “hidden” in long sentences and I oversee that. I somehow struggle with the Confluence style too…
But there is someone who has read it and gives you a hand :wink:
And he only has one eye!!
all the more amazing!
The Eye of Barad-dûr
Just some history :wink:
Avatar 2014-2020
Avatar 2021
Avatar from 2022-02-24
Avatar for 2023-02-24
Avatar for 1st April 2023
Actual Avatar
Is there a similarity to the second? :laughing:
So … in the last two years you made a transition from right to left? :open_mouth:
And only that … your hair became grey? Is that how old you are? :laughing:
The last is the old Windows XP user login picture icon, with a surprise if is zoomed :wink: (like the original…)
You can use dns over wireguard instead of doh. For example cloudflare warp with their dns servers.
