Dns is unreachable
Hi, I’m quite new with the RadioBoard setup and all, I’ve got a RB411u with a MC8705 sierra wireless modem. I have set it up, and it connects to the 3g network (it says connected). My Ethernet connection on the PC says connected to the internet, but i can not browse to eny web site, so i reset the config and started again, and now my Ethernet connection on the PC says limited access or on internet access, and yes i have setup a NAT where Action=masquerade chain=srcnat.
Could anyone help, or advise me on how to proceed.
Thanks.
Do you have dns setup on the router properly? It sounds like maybe not. See if you can ping a hostname, and see if you can ping an ip address directly.
For the NAT, did you specify a ethernet port or an address range??? That is important.
