Hi experts, I’m kindly asking for help. I have trunk on my interfaces, and according to docs I need to create same VLAN and bridge them together. It is working, but I have issue with DNS on my bridge-home.
Ping on interface if working, but DNS request not.
Pinging 192.168.2.1 with 32 bytes of data:
Reply from 192.168.2.1: bytes=32 time=3ms TTL=64
Reply from 192.168.2.1: bytes=32 time<1ms TTL=64
Reply from 192.168.2.1: bytes=32 time=1ms TTL=64
nslookup google.com 192.168.2.1
;; communications error to 192.168.2.1#53: timed out
;; no servers could be reached
I have assigned same IP to my vlan2-home-eX interfaces,
/ip/address/print
Flags: X - DISABLED, D - DYNAMIC; S - SLAVE
Columns: ADDRESS, NETWORK, INTERFACE
# ADDRESS NETWORK INTERFACE
0 S 192.168.2.1/24 192.168.2.0 vlan2-home-e2
1 X 192.168.1.55/24 192.168.1.0 vlan1-mngmt-e2
2 192.168.9.1/24 192.168.9.0 bridge-guest
3 172.31.254.2/32 172.31.254.2 Loopback1
4 192.168.1.1/24 192.168.1.0 bridge-mngmt
5 192.168.8.1/24 192.168.8.0 bridge-smarthome
6 X 192.168.6.1/24 192.168.6.0 vlan6
7 192.168.2.1/24 192.168.2.0 bridge-home
8 X 46.151.56.137/29 46.151.56.136 ether1-wan
9 S 192.168.2.1/24 192.168.2.0 vlan2-home-e3
10 S 192.168.2.1/24 192.168.2.0 vlan2-home-e4
11 S 192.168.2.1/24 192.168.2.0 vlan2-home-e5
12 D 46.151.56.137/28 46.151.56.128 ether1-wan
when I change one interface to different IP, then DNS on that interface is working
/ip/address/print
0 S 192.168.2.254/24 192.168.2.0 vlan2-home-e2
nslookup google.com 192.168.2.254
Server: 192.168.2.254
Address: 192.168.2.254#53
Non-authoritative answer:
Address: 142.251.208.174
Address: 2a00:1450:400d:808::200e
but when I change IP again to 192.168.2.1, then DNS requests does not work.
Here is part of my config, with interfaces and ip export.
interfaces_ip.txt (31.6 KB)
Yes, I’m not an expert. Any help ? Thank You.
