DNS Issues in Station Mode
I’ve had this HAP ax2 in Station Mode for a while now, and it works great. I’m basically using it to get ethernet-only clients a wireless connection.
However, the DNS has never worked for the HAP ax2 itself. Works for the clients, that’s just passthrough, but the HAP ax2 has no resolution. This, of course, affects updates mainly, since it can never resolve update servers.
Is this just how Station Mode works? I’ve tried a bunch of things, but can never seem to get DNS resolution running on the device when it’s in Station Mode.
Config:
# 2024-05-10 13:47:58 by RouterOS 7.15rc2
# software id = WU29-BLCC
# model = C52iG-5HaxD2HaxD
# serial number = (serial)
add name=bridge1
/interface wifi
set [ find default-name=wifi1 ] channel.band=5ghz-ax .frequency=5805 .skip-dfs-channels=all .width=20mhz configuration.country="United States" .mode=station-bridge .ssid=Hector disabled=no
set [ find default-name=wifi2 ] configuration.mode=station
/interface wifi security
add authentication-types=wpa3-psk disabled=no encryption=ccmp-256,gcmp-256 name=sec1
/ip smb users
add bridge=bridge1 interface=wifi1
set udp-timeout=10s
/ipv6 settings
set disable-ipv6=yes
add address=10.62.14.6/24 interface=wifi1 network=10.62.14.0
set servers=94.140.14.49,94.140.14.59,10.62.14.1
/ip smb shares
set [ find default=yes ] directory=/pub
/system clock
set time-zone-name=America/New_York
/system identity
set name=livingroom-client-ap
/system logging
add action=email topics=critical,warning,account
/system note
set show-at-login=no
/system ntp client
set enabled=yes
/system ntp client servers
add address=10.62.14.1
/system package update
set channel=testing
A few things:
  1. move IP address from wifi1 interface to bridge interface (probably not the show stopper, but it’s wrong anyway)
  2. add default route, e.g.
/ip/route/add gateway=10.62.14.1
(I’m assuming this is the address of your main router)
OMG so dumb. Thanks, that was totally it, I just missed the route.
