I have RB850Gx2, Router OS v6.30.4 installed with this configuration
port 1 - WAN
port 2 & 3 - to Switch for LAN
port 4 - to Internal Server
port 5 - to Wifi Router
203.142.xxx is my ISP DNS, while 192.168.1.5-10 is my Internal server work for domain controller and intranet thingy.
All PC and other device can communicate through internal network just fine.
Wifi Router is set as bridge and controlled by DHCP on port 5 mikrotik. It’s work fine, can connect internal and browse internet.
Client PC is set with static IP, but somehow it behave erratic with unpredict behaviour when try to browse internet.
Sometimes it’s connect, sometimes it don’t and showed DNS error. The strange bit is, it doesnt have the same behaviour through all the PC.
PC with Windows XP is work fine, while PC with Windows 7 and 8, behave erratic and often lost connection because it can’t solved DNS.
WAN is obviously connect and DNS working fine because all wifi device can connect to internet, ping internet domain on terminal also confirmed this, it’s connected and can solve DNS.
Reboot Mikrotik Router solve this problem.
But, after a while.. 15 minutes or so. The problem comeback with PC on windows 7/8, some affected, some not.
It seems random about who get affected, different client everytime. Sometimes the problem gone for a while, then comeback unexpetedly.
I try add DHCP Server for LAN on PC Network and add DNS Server to that. But it doesn’t solve the problem, still same result.
Originally, this problem is on my old RB450G.
It work fine previously and this problem just recently came (perhaps because previously it have majority of Windows XP installed, but now majority is Windows 7/8?)
But because it already served for several years, I assumed maybe there’s something wrong with the device and replace it with the newer RB850Gx2.
Turns out the problem still exist.
Can someone point me what’s wrong in the configuration and what to do to solve this?
