dns name exists but no appropriate record
hi there..
last night i have problem with dns mikrotik. when i try to ping 8.8.8.8 and another ip, success. but when i try ping for example google.com or another i had a replay
"dns name exists but no appropriate record’
mikrotik i used ccr1009 7g-1s+1c with RouterOS 6.47.4
i try to upgrade manual with pc and transfer it by winbox, to 6.49 and result is same
i try reset configuration with no default config.. and you know the result
thanks
