Dns names to dhcp clients
Hi, I would like to add the possibility to access clients connected via static ip (and even dhcp if possible) using a dns name like CLIENTNAME.home.local or CLIENTNAME. Local. At the moment I have only added the domain “home.local” to the network setting window and set some static dns hostnames in dns>static window. I am not very expert on routeros because I am using it since only 1 month…so anyone can explain me what I have to do? Thanks!
In dns page my dns is the ISP’s modem connected to ether1wan port, alternate dns are the ones provided by the ISP. The router is PPPoE connected to the other modem that is in Bridge mode.
You can static DNS on the Routerboard for pc1.local as 192.168.101 or whatever you wish. But your PCs must be using the Routerboard as their DNS server.
