It's the same using technitium DOQ, the singular connection is Adguard Public servers while the multiple connections are to Quad9 DOQ again. Note the data on single vs the multiple. also I'll show another graph, the red server errors are Quad9 and the queries either side are me moving from Adguard then back again so the middle section being Quad9. The secret maybe be in what quad9 use ie unbound/powerdns/ etc.
I've tried a lot of proxies which mainly give trouble. I'll try knot-resolver6 later.
pato1
November 4, 2026, 6:17pm
42
I checked the RouterOS changelogs and on the development 7.26beta1 version I saw: dns - improve service stability on HTTP/2 DoH connections;
Anybody checked it if it fixed the quad9 DoH problem?
Seems to work for me on RB5009 running 7.24.6 long-term
drotz
November 4, 2026, 11:24pm
44
Can you share /dns and certificates that you have, have u imported any, have u bootstrapped the DoH or no?
Cus i've done all that, including their dns servers, their DoH link, bootstrapped it correctly and imported their certs and my router been spammed in logs with "DoH server response not OK: 0:" warnings.
To be fair its been a few updates since then and i haven't given it a thought or a test.
A bit off-topic, but I'm currently using Cloudflare DoH on my hAP ax2.
I'm curious about what makes Quad9 so special. I've seen it mentioned quite frequently in various discussions, so I thought I'd ask.
From a security perspective, is Quad9 actually better than Cloudflare? What are its main advantages, and why would someone choose it over Cloudflare?
I'd appreciate it if someone could shed some light on this. Perhaps you might even convince me to make the switch! Thanks
The reason, in my opinion?
They publicly commit to maintaining data privacy in any context.
Furthermore, they have faced various legal challenges from governments demanding that they implement certain types of blocks—demands they have refused to meet. They have even gone so far as to shut down their operating nodes in certain countries, rather than allowing those nodes to handle requests differently (i.e., by applying blocks).
set allow-remote-requests=yes cache-size=49152KiB doh-max-concurrent-queries=\
200 doh-max-server-connections=10 max-concurrent-queries=200 \
max-concurrent-tcp-sessions=50 use-doh-server=\
https://dns.quad9.net/dns-query verify-doh-cert=yes
and also
add address=9.9.9.9 comment="DO NOT DELETE - used for DoH" name=dns.quad9.net \
type=A
add address=149.112.112.112 comment="DO NOT DELETE - used for DoH" name=\
dns.quad9.net type=A
The certificates I've imported to this router was afair Mozilla's CA certificate list.
These warnings still happen in the logs but local DNS server seems to be working just fine.
Long story short they refuse censorship. Read this for further information: https://quad9.net/news/blog/au-revoir-france/
You can see Adguard Vs Quad9 in the following graph which I posted earlier. The middle section is quad9 with elevated RED lines (errors) vs Adguard the Red lines go flat. The errors are real make no mistake.
The test was moving from Adguard to Quad9 and back again 20 minutes each.
wfbuton
November 5, 2026, 6:25pm
49
here you go
openssl s_client -4 -servername dns.quad9.net -connect dns.quad9.net:443 -showcerts
Connecting to 9.9.9.9
CONNECTED(00000003)
depth=2 C=US, O=DigiCert Inc, OU=www.digicert.com, CN=DigiCert Global Root G3
verify return:1
depth=1 C=US, O=DigiCert Inc, CN=DigiCert Global G3 TLS ECC SHA384 2020 CA1
verify return:1
depth=0 C=CH, ST=Zurich, L=Zürich, O=Quad9, CN=dns.quad9.net
verify return:1
Certificate chain
0 s:C=CH, ST=Zurich, L=Zürich, O=Quad9, CN=dns.quad9.net
i:C=US, O=DigiCert Inc, CN=DigiCert Global G3 TLS ECC SHA384 2020 CA1
a:PKEY: EC, (prime256v1); sigalg: ecdsa-with-SHA384
v:NotBefore: Jul 17 00:00:00 2026 GMT; NotAfter: Jan 31 23:59:59 2027 GMT
-----BEGIN CERTIFICATE-----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-----END CERTIFICATE-----
1 s:C=US, O=DigiCert Inc, CN=DigiCert Global G3 TLS ECC SHA384 2020 CA1
i:C=US, O=DigiCert Inc, OU=www.digicert.com, CN=DigiCert Global Root G3
a:PKEY: EC, (secp384r1); sigalg: ecdsa-with-SHA384
v:NotBefore: Apr 14 00:00:00 2021 GMT; NotAfter: Apr 13 23:59:59 2031 GMT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Server certificate
subject=C=CH, ST=Zurich, L=Zürich, O=Quad9, CN=dns.quad9.net
issuer=C=US, O=DigiCert Inc, CN=DigiCert Global G3 TLS ECC SHA384 2020 CA1
No client certificate CA names sent
Peer signing digest: SHA256
Peer signature type: ecdsa_secp256r1_sha256
Peer Temp Key: X25519, 253 bits
SSL handshake has read 3466 bytes and written 1635 bytes
Verification: OK
New, TLSv1.3, Cipher is TLS_AES_256_GCM_SHA384
Protocol: TLSv1.3
Server public key is 256 bit
This TLS version forbids renegotiation.
Compression: NONE
Expansion: NONE
No ALPN negotiated
Early data was not sent
Verify return code: 0 (ok)
Post-Handshake New Session Ticket arrived:
SSL-Session:
Protocol : TLSv1.3
Cipher : TLS_AES_256_GCM_SHA384
Session-ID: 6427C4E140133C9B7E1D9EEEFEBFDD748E45197A9E35DE7B15F0CCEC5C223E97
Session-ID-ctx:
Resumption PSK: 64581E6CFF5216D1C601CC6C96508D0F2D46981B2F96CA54C0C1DE27B5665638E425985968EE10B6D8600C2C791435CD
PSK identity: None
PSK identity hint: None
SRP username: None
TLS session ticket lifetime hint: 7200 (seconds)
TLS session ticket:
0000 - 6a 7c c0 cb 1c 87 7c f9-24 cd 1b 52 6a 1f ca 53 j|....|.$..Rj..S
0010 - b7 f4 c5 7f e5 0b 9b ee-0a aa c4 51 df 24 97 81 ...........Q.$..
0020 - dd 07 d9 79 fd ab 12 03-56 95 8e 6a 29 8c 25 44 ...y....V..j).%D
0030 - 1a 09 d7 77 20 52 70 49-40 f7 4d 1f 90 1c 5c 43 ...w RpI@.M...\C
0040 - da 6a 54 1e 1f 8b c6 ba-93 a9 41 18 a3 85 e3 bf .jT.......A.....
0050 - b5 66 a7 f0 6a 31 d7 e3-b1 d4 12 04 42 17 90 35 .f..j1......B..5
0060 - da c2 51 21 80 64 02 c2-46 c3 df e5 de 11 45 bb ..Q!.d..F.....E.
0070 - 3a 1b ad 01 b0 23 3e c1-65 60 51 26 a8 51 32 2b :....#>.e`Q&.Q2+
0080 - cd 97 12 93 ac 27 92 5c-9c c3 aa 9e 73 76 b6 4f .....'.\....sv.O
0090 - 04 19 6b 4d f1 93 af 48-bd 76 aa fd 5d f8 64 db ..kM...H.v..].d.
00a0 - 27 c0 eb 13 33 37 d2 47-4a 40 f7 32 b5 41 67 3d '...37.GJ@.2.Ag=
00b0 - 19 34 18 90 07 2c 66 f4-18 14 44 2a 49 61 a0 00 .4...,f...D*Ia..
00c0 - f2 b6 69 ff 50 cc 46 04-c8 40 5d c9 6f e6 ca f3 ..i.P.F..@].o...
00d0 - bf 08 fd f0 ac d8 21 23-59 1a 49 fe d4 89 c5 f9 ......!#Y.I.....
Start Time: 1793902947
Timeout : 7200 (sec)
Extended master secret: no
Max Early Data: 0
read R BLOCK
SSL-Session:
Protocol : TLSv1.3
Session-ID: 46EB1E6544576DD530A06716A3C1AB91DDA514C09E09CABEBCB653A99B683134
Session-ID-ctx:
Resumption PSK: 925834C0EC0CBD5569680A69D74F9DDFC66C0DE1C85D6DA8E22ACD03213858817338A22EA452B67A7F0F8429EE38E9D1
PSK identity: None
SRP username: None
TLS session ticket:
0010 - af 4d 85 f8 a7 67 21 af-ba 31 ae 75 1e bf e2 d3 .M...g!..1.u....
0020 - 32 3b 58 80 77 ed a8 8d-2a 0d 8b 04 5d c8 1e aa 2;X.w...*...]...
0030 - 8b 67 2a 43 9d fd 4f 6e-dc 28 b8 b9 bd e6 07 95 .g*C..On.(......
0040 - 6b b2 1e 1b 30 25 66 a9-11 96 bd 20 9a f6 96 75 k...0%f.... ...u
0050 - 9f 40 28 bc cc 98 f0 7d-8e 98 98 b8 a8 9d 6e 18 .@(....}......n.
0060 - eb 3e ed 78 bb 8c 39 9f-6b e9 98 0b 51 ec 6d c1 .>.x..9.k...Q.m.
0070 - 89 83 c8 c9 65 ae d3 c9-b1 68 a1 2d 57 0c 89 a2 ....e....h.-W...
0080 - 44 86 c6 ad 9d b9 ab 40-c3 f1 09 68 a2 4b 86 0f D......@...h.K..
0090 - 1f 61 22 16 70 98 a4 8d-b5 f6 d1 7a 57 9f ab be .a".p......zW...
00a0 - 8e 03 06 b4 22 2d 1f 66-7b 9a f3 44 6e 60 f4 b1 ...."-.f{..Dn`..
00b0 - 8f 78 fc fe 82 a1 01 74-17 b4 fe e4 e2 bf dc 57 .x.....t.......W
00c0 - b0 18 88 f5 79 70 ec 7b-24 4b 62 9e d6 53 49 29 ....yp.{$Kb..SI)
00d0 - cf 0f 62 14 5c a6 77 f4-65 f7 e6 7d b4 71 48 db ..b.\.w.e..}.qH.
Max Early Data: 0
read R BLOCK
HTTP/1.1 505 HTTP Version Not Supported
Connection: Close
Date: Thu, 05 Nov 2026 18:22:28 GMT
<html><body>This server implements RFC 8484 - DNS Queries over HTTP, and requires HTTP/2 in accordance with section 5.2 of the RFC.</body></html>
closed
drotz
November 5, 2026, 7:16pm
50
Well i had the same issue with the log spam, it worked and it was resolving the domain names and it was working fine.
It was just spamming the router logs and i just stopped using it because of that, didnt see much point over cloudflare which worked and did the same thing + didnt spam logs with bogus warnings.
