Hi all,
I installed Pi Hole (dns ad blocker) on the network with a static ip of 192.168.88.3. DHCP server on the Mikrotik point to 192.168.88.3 as DNS server and so do any of my static IP addresses. I have also added a few NAT rules to force DNS queries to the Pi Hole. My filter and NAT roles below.
Originally, I had filter rules 0-10 on and NAT rules 0-5 (all) on.
Then I noticed that there were some DNS queries made to my Pi Hole from external IP addresses. I also did a port scan using the GRC shields up interface. Port 53 was open.
So I added filter rules 11 and 12 to try to block external DNS queries to port 53.
However even with those rules enabled, GRC still said that my port 53 was open. Please help. What am I doing wrong here?
Filter Rules
0 D ;;; special dummy rule to show fasttrack counters
chain=forward action=passthrough
1 ;;; defconf: accept established,related,untracked
chain=input action=accept connection-state=established,related,untracked
2 ;;; defconf: drop invalid
chain=input action=drop connection-state=invalid
3 ;;; defconf: accept ICMP
chain=input action=accept protocol=icmp
4 ;;; defconf: drop all not coming from LAN
chain=input action=drop in-interface-list=!LAN
5 ;;; defconf: accept in ipsec policy
chain=forward action=accept ipsec-policy=in,ipsec
6 ;;; defconf: accept out ipsec policy
chain=forward action=accept ipsec-policy=out,ipsec
7 ;;; defconf: fasttrack
chain=forward action=fasttrack-connection
8 ;;; defconf: accept established,related, untracked
9 ;;; defconf: drop invalid
chain=forward action=drop connection-state=invalid
10 ;;; defconf: drop all from WAN not DSTNATed
chain=forward action=drop connection-state=new
connection-nat-state=!dstnat in-interface-list=WAN
11 ;;; Drop external DNS TCP
chain=input action=drop protocol=tcp in-interface-list=WAN dst-port=53
log=no log-prefix=""
12 ;;; Drop external DNS UDP
chain=input action=drop protocol=udp in-interface-list=WAN dst-port=53
log=no log-prefix="
NAT rules
0 ;;; defconf: masquerade
chain=srcnat action=masquerade out-interface-list=WAN log=no log-prefix="" ipsec-policy=out,none
1 chain=dstnat action=dst-nat to-addresses=192.168.88.3 protocol=udp src-address=!192.168.88.3
dst-address=!192.168.88.3 dst-port=53 log=no log-prefix=""
2 chain=dstnat action=dst-nat to-addresses=192.168.88.3 protocol=tcp src-address=!192.168.88.3
3 chain=srcnat action=masquerade protocol=udp src-address=192.168.88.0/24 dst-address=192.168.88.3 dst-port=53
4 chain=srcnat action=masquerade protocol=tcp src-address=192.168.88.0/24 dst-address=192.168.88.3 dst-port=53
5 ;;; Plex MSI
chain=dstnat action=dst-nat to-addresses=192.168.88.51 to-ports=32400 protocol=tcp
dst-address=[MY PUBLIC IP] in-interface=ether1 dst-port=32401 log=no log-prefix=""
