DNS problem when hotspot activated
Hi.
I´m using 6.42.2 . All on the system is running fine, but when i activate my hotspot, DNS is not working?!!
What can be the problem?
check what DNS do your hotspot clients get?
Check… sorry. Everything is working. DNS HTTP and HTTPS. When i actived the hotspot, user´s can login and after that … nothing. No page (URL) is available. I cant open anything.
is your hotspot DHCP pool correct? if it is diffirent from you LAN DHCP pool, does the hotspot pool get correctly NAted?
He is using the same pool.
please can you post
export hide-sensitive
[admin@Tik-Bistro-Damp] > export hide-sensitive
may/23/2018 08:02:52 by RouterOS 6.42.2
software id = FGJK-B0II
model = 750GL
serial number = 467A04D3F715
add admin-mac=4C:5E:0C:D4:9D:89 auto-mac=no comment="created from master port"
name=bridge1 protocol-mode=none
set [ find default-name=ether2 ] name=ether2-master
/interface pptp-client
add connect-to=utm01.camping-spot.de disabled=no name=pptp-out1 user=
rxxxxxxxxxxxxx
/interface vlan
add interface=bridge1 name=vlan100 vlan-id=100
add exclude=dynamic name=discover
add name=mactel
add name=mac-winbox
/ip hotspot profile
add dns-name=damp.login hotspot-address=10.4.40.1 html-directory=dorotheenthal
html-directory-override=dorotheenthal login-by=cookie,http-chap,http-pap
name=hsprof1 radius-location-id=dorotheenthal-bistro use-radius=yes
/ip hotspot user profile
add idle-timeout=30m name=putze shared-users=2 transparent-proxy=yes
add name=default-dhcp ranges=192.168.2.50-192.168.2.254
add name=dhcp_pool5 ranges=10.4.40.2-10.4.43.254
add address-pool=default-dhcp disabled=no interface=bridge1 lease-time=1d10m
name=defconf
add address-pool=dhcp_pool5 disabled=no interface=vlan100 lease-time=1d10m
name=dhcp1
/ip hotspot
add address-pool=dhcp_pool5 idle-timeout=15m interface=vlan100 name=hotspot1
profile=hsprof1
set [ find default=yes ] address-pool=dhcp_pool5 idle-timeout=30m
/tool user-manager customer
set admin access=
own-routers,own-users,own-profiles,own-limits,config-payment-gw
add bridge=bridge1 interface=ether2-master
set discover-interface-list=all
add interface=bridge1 list=discover
add interface=ether3 list=discover
add interface=ether4 list=discover
add interface=ether5 list=discover
add interface=bridge1 list=mactel
add interface=bridge1 list=mac-winbox
add address=192.168.2.1/24 comment=defconf interface=ether2-master network=
192.168.2.0
add address=10.4.40.1/22 interface=vlan100 network=10.4.40.0
add address=192.168.88.222/24 interface=bridge1 network=192.168.88.0
/ip dhcp-client
add comment=defconf dhcp-options=hostname,clientid disabled=no interface=ether1
add address=10.4.40.0/22 dns-server=10.4.40.1 gateway=10.4.40.1
add address=192.168.2.0/24 comment=defconf dns-server=192.168.2.1 gateway=
192.168.2.1
set allow-remote-requests=yes cache-size=8192KiB max-concurrent-queries=1000
max-concurrent-tcp-sessions=200 servers=192.168.2.1,217.237.150.225,8.8.8.8
/ip dns static
add address=10.4.40.1 disabled=yes name=dorotheenthal.camping-spot.login
add address=10.4.40.1 name=damp.login
add address=10.15.23.20 name=paypal.camping-spot.login
add action=passthrough chain=unused-hs-chain comment="place hotspot rules here"
disabled=yes
add action=accept chain=input comment="defconf: accept established,related"
add action=drop chain=input comment="defconf: drop all from WAN" in-interface=
ether1
add action=fasttrack-connection chain=forward comment="defconf: fasttrack"
add action=accept chain=forward comment="defconf: accept established,related"
add action=drop chain=forward comment="defconf: drop invalid" connection-state=
invalid
"defconf: drop all from WAN not DSTNATed" connection-nat-state=!dstnat
connection-state=new in-interface=ether1
add action=accept chain=input dst-port=8291 protocol=tcp
add action=accept chain=hotspot dst-port=53 protocol=udp to-ports=64872
add action=accept chain=hotspot dst-port=53 protocol=tcp to-ports=64872
disabled=yes
add action=masquerade chain=srcnat comment="defconf: masquerade" out-interface=
ether1
add action=masquerade chain=srcnat comment="masquerade hotspot network"
src-address=10.4.40.0/24
add action=dst-nat chain=dstnat dst-port=7443 protocol=tcp to-addresses=
192.168.2.2 to-ports=7443
src-address=192.168.2.0/24
/ip hotspot user
set [ find default=yes ] limit-uptime=30m
add name=admin
add name=5555 profile=putze server=hotspot1
/ip hotspot walled-garden
add comment="place hotspot rules here" disabled=yes
add dst-host=:^.akamaiedge.net server=hotspot1 src-address=0.0.0.0
add dst-host=:^radius-doro.camping-spot.de
add dst-host=:[1](http://www.paypalobjects.com)
add dst-host=:[2](http://www.paypal.com)
add dst-host=:[3](http://www.paypal.de)
add dst-host=:^content.paypalobjects.com
/ip hotspot walled-garden ip
add action=accept disabled=no dst-address=10.15.23.20 !dst-address-list
!dst-port protocol=tcp server=hotspot1 src-address=0.0.0.0
!src-address-list
add action=accept comment="ppobj may/23/2018" disabled=no dst-address=
92.123.40.198
add action=accept comment="ppj may/23/2018" disabled=no dst-address=23.52.12.83
23.52.14.182
add action=accept comment="ppobj may/21/2018" disabled=no dst-address=
23.194.204.198
104.84.145.75
add action=accept comment="ppobj apr/06/2018" disabled=no dst-address=
95.100.200.237
23.211.1.19
add action=accept comment="ppobj apr/06/2018" disabled=no dst-address=23.45.1.6
add action=accept comment="ppobj may/20/2018" disabled=no dst-address=
23.44.105.6
add action=accept comment="ppobj may/22/2018" disabled=no dst-address=
2.19.105.19
add action=accept comment="ppobj may/14/2018" disabled=no dst-address=
104.81.34.199
add action=accept comment="pp may/01/2018" disabled=no dst-address=23.44.109.7
23.53.173.13
add action=accept disabled=no dst-port=53 protocol=udp
add action=accept disabled=no dst-port=53 protocol=tcp
add distance=1 dst-address=10.15.23.0/24 gateway=pptp-out1
/ip service
set www-ssl certificate=www_camping-spot_de.crt_0 disabled=no
set winbox address=0.0.0.0/0
/radius
add address=10.15.23.20 service=ppp,hotspot timeout=3s
/snmp
set contact=dirk.westphal@camping-spot.de enabled=yes location=
"Dororthenthal Bistro" trap-interfaces=pptp-out1 trap-version=2
/system clock
/system identity
set name=Tik-Bistro-Damp
/system logging
add topics=radvd
add topics=radius,debug
add topics=hotspot,info
add topics=dns
add disabled=yes topics=firewall,info
add disabled=yes topics=firewall,debug
add topics=dhcp,debug
/system routerboard settings
set silent-boot=no
/system scheduler
add interval=10m name=paypal on-event=paypal policy=
ftp,reboot,read,write,policy,test,password,sniff,sensitive,romon
start-date=apr/04/2018 start-time=05:11:54
add interval=23h name=cleanup on-event=cleanup policy=
start-date=apr/04/2018 start-time=05:12:10
/system script
add name=paypal owner=admin policy=
ftp,reboot,read,write,policy,test,password,sniff,sensitive,romon source=":lo
cal ppobjip [:resolve www.paypalobjects.com];\r
\n:local today [/system clock get date];\r
\n:local paypalobject [/ip hotspot walled-garden ip find dst-address=$ppobj
ip];\r
\n:local thisdate none;\r
\n:local noip true;\r
\n\r
\n:foreach i in=$paypalobject do={\r
\n :set noip false;\r
\n :set thisdate [/ip hotspot walled-garden ip get $i comment];\r
\n :if ($thisdate != ("ppobj $today")) do={\r
\n /ip hotspot walled-garden ip set $i comment="ppobj $today"
;\r
\n }\r
\n}\r
\n\r
\n:if ($noip) do={\r
\n :log info "paypal script adding $ppobjip";\r
\n /ip hotspot walled-garden ip add dst-address=$ppobjip comment="ppobj
_$today";\r
\n}\r
\n\r
\n:local ppjip [:resolve www.paypal.com];\r
\n:local paypal [/ip hotspot walled-garden ip find dst-address=$ppjip];\r
\n\r
\n:foreach i in=$paypal do={\r
\n :if ($thisdate != ("pp $today")) do={\r
\n /ip hotspot walled-garden ip set $i comment="ppj $today";
\r
\n }\r
\n}\r
\n\r
\n :log info "paypal script adding $ppjip";\r
\n /ip hotspot walled-garden ip add dst-address=$ppjip comment="pp $to
day";\r
\n}"
add name=cleanup owner=admin policy=
\n:local old [/ip hotspot walled-garden ip find comment~"ppobj*"];\r
\n:global thisrem none;\r
\n:global thisip none;\r
\n\r
\n:foreach i in=$old do={\r
\n :set thisrem [/ip hotspot walled-garden ip get $i comment];\r
\n\r
\n :if ($thisrem != ("ppobj $today")) do={\r
\n /ip hotspot walled-garden ip remove $i;\r
\n }\r
\n}\r
\n\r
\n:local old [/ip hotspot walled-garden ip find comment~"pp*"];\r
\n\r
\n\r
\n :if ($thisrem != ("pp $today")) do={\r
\n }"
/tool mac-server
set allowed-interface-list=mactel
/tool mac-server mac-winbox
set allowed-interface-list=mac-winbox
/tool user-manager database
set db-path=user-manager
  1. www.paypalobjects.com ↩︎
  2. ↩︎
  3. ↩︎
