atbizz
August 20, 2024, 8:31am
1
Mikrotik OS 7.15.3, router C53UiG+5HPaxD2HPaxD,
DNS server responds differently to the same requests depending on whether DOH used or not, causing a resolving problems on clients.
(static A record on DNS: box.lan = 192.168.1.5)
If DNS servers = 1.1.1.1
nslookup box.lan
Server: 127.0.0.11
Address: 127.0.0.11:53
Non-authoritative answer:
Address: 192.168.1.5
if Use DOH server https://1.1.1.1/dns-query:
nslookup box.lan
Server: 127.0.0.11
** server can't find box.lan: NXDOMAIN
Incorrect DNS reply if no AAAA record, this misbehavior cause problems in docker…
optio
August 20, 2024, 4:31pm
2
nslookup box.lan
Server: 127.0.0.11
I somehow doubt this is response from ROS DNS:..
If DNS IP for container is not set (dns config), in /etc/resolv.conf file in container nameserver is set to upstream DNS IP(s) of ROS DNS (servers or dynamic-servers ), not ROS DNS IP, you need to manually specify in dns container config ROS DNS IP (gateway IP) to be used for container (to be able to resolve static entries set in ROS DNS for some reason), also make sure that container have input allowed for port 53 if container connections are filtered.
atbizz
August 21, 2024, 4:59pm
3
More correct version from host (previous were from docker container running on host box.lan):
nslookup box.lan
Server: 192.168.1.1
Address: 192.168.1.1#53
And with DOH:
nslookup box.lan
Server: 192.168.1.1
Everything absolutely the same like inside container, because:
cat /etc/resolv.conf
# Resolver configuration file.
# See resolv.conf(5) for details.
nameserver 192.168.1.1
domain lan
search lan
and docker:
cat /etc/docker/daemon.json
"dns" : ["192.168.1.1"],
"dns-search" : ["lan"],
192.168.1.1 - mikrotik router with DNS server.
optio
August 21, 2024, 6:53pm
4
Yes, can reproduce this, it seems this is a bug in ROS DNS.
Without DoH:
$ dig A @192.168.100.1 tvbox.lan
; <<>> DiG 9.10.6 <<>> A @192.168.100.1 tvbox.lan
; (1 server found)
;; global options: +cmd
;; Got answer:
;; ->>HEADER<<- opcode: QUERY, status: NOERROR, id: 30291
;; flags: qr rd ra; QUERY: 1, ANSWER: 1, AUTHORITY: 0, ADDITIONAL: 0
;; QUESTION SECTION:
;tvbox.lan. IN A
;; ANSWER SECTION:
tvbox.lan. 86400 IN A 192.168.100.20
;; Query time: 45 msec
;; SERVER: 192.168.100.1#53(192.168.100.1)
;; WHEN: Wed Aug 21 20:44:50 CEST 2024
;; MSG SIZE rcvd: 43
$ dig AAAA @192.168.100.1 tvbox.lan
; <<>> DiG 9.10.6 <<>> AAAA @192.168.100.1 tvbox.lan
; (1 server found)
;; Got answer:
;; ->>HEADER<<- opcode: QUERY, status: NOERROR, id: 35536
;; flags: qr rd ra; QUERY: 1, ANSWER: 0, AUTHORITY: 0, ADDITIONAL: 0
;tvbox.lan. IN AAAA
;; Query time: 62 msec
;; WHEN: Wed Aug 21 20:44:53 CEST 2024
;; MSG SIZE rcvd: 27
NOERROR is returned for A and AAAA queries
With DoH:
; (1 server found)
;; Got answer:
;; ->>HEADER<<- opcode: QUERY, status: NOERROR, id: 23932
;tvbox.lan. IN A
;; ANSWER SECTION:
;; Query time: 44 msec
;; WHEN: Wed Aug 21 20:41:57 CEST 2024
; (1 server found)
;; Got answer:
;; ->>HEADER<<- opcode: QUERY, status: NXDOMAIN, id: 38456
;; flags: qr rd ra; QUERY: 1, ANSWER: 0, AUTHORITY: 1, ADDITIONAL: 0
;tvbox.lan. IN AAAA
;; AUTHORITY SECTION:
. 86383 IN SOA a.root-servers.net. nstld.verisign-grs.com. 2024082101 1800 900 604800 86400
;; Query time: 50 msec
;; WHEN: Wed Aug 21 20:42:03 CEST 2024
;; MSG SIZE rcvd: 102
NOERROR is returned for A, but NXDOMAIN for AAAA query
I actually got the same problem, just that i only have AAAA records and no A records. I think the mikrotik, if doh is enabled, treats the A and AAAA requests seperately and therefore forwards the request for which it doesnt have an entry to the doh server. a public dns then obviously returns nxdomain and the mikrotik is sending this to the client/docker container.
i hope they fix this, but it should be possible as it works with normal dns servers. just not for doh.
dksoft
September 13, 2024, 8:12am
6
Thanks @atbizz for the solution!
I can confirm the problem which breaks certain Alpine based installations. Removing DoH fixes it for now.
Here is a description what is causing the problem: https://www.home-assistant.io/more-info/unsupported/dns_server/
atbizz
September 10, 2025, 2:11pm
7
ROS 7.19.4 and problem with DOH DNS still exists, how to push a solution?
optio
September 10, 2025, 4:28pm
8
If you have device which can run containers try with some DNS server (ie. Unbound) running in container.
