Hi all,
I’m having a problem with my Mikrotik Server. The current Set up is:
2 Ethernet cards, Local IP Range 10.5.5.0/24 Server IP 10.5.5.1
Public IP 83.220.200.112 with Gateway 83.220.200.126
This was routing perfectly using masquerading NAT but yesterday something strange happened. It stopped loading many Web pages.
I know this is a DNS Problem but i’m at a loss as to how to fix it. I’ve even tried to set external DNS Servers that I know are working properly but the server seems to be blocking the DNS Requests.
Can anybody shed some light on this for me as I have many irate customers who are without proper internet access at the moment.
I think you need to post a little more information about your setup. Are you using webproxy? What kind of firewall have you setup? Using torch and/or the traffic sniffer, you should be able to determine where your traffic is hanging up. Also, what type of Internet connection is this hooked up to (T1/T3, DSL, Sat, etc)?
The reason you’re not seeing a MT at that address is because i removed it and put a Zyxel in it’s place until i can figure out what’s going on. When it was in place i could type in any url on the MT and ping it no problem, it just seemed to stop routing traffic. I’m not using webproxy at all.
I’ve decided to just do a master reset on the box but i would still like to get to the bottom of what went wrong. I think it may have been hacked as when i telnetted into it i saw a lot of login attempts from external addresses.
My DNS Server still isn’t working properly.
In the settings I have the Primary DNS Set to 217.114.173.6 and the secondary set to 82.195.128.132 and i have Allow Remote requests Checked.
When i Try an nslookup using my server it responds with:
Has anyone seen this before? The response from the server seems strange to me. When i set my PC to the DNS Servers I showed above, i have full access to all pages.
I have Masquerading set up as in:
Chain=srcnat
out-interface=ether2
action=masquerade.
How do you mean my masquerading outgoing DNS requests?
Also checking the DNS Cache revealed the following few lines that to me seem odd:
Name, Type, Data
1.10.168.192.in-addr.arpa, PTR, rfc1918.space.should.not.be.used.on.publicips
1.3.168.192.in-addr.arpa, PTR, rfc1918.space.should.not.be.used.on.publicips
1.5.5.10.in-addr.arpa, PTR, rfc1918.space.should.not.be.used.on.publicips
10.in-addr.arpa, NS, localhost
10.in-addr.arpa, NS, blackhole-1.iana.org
10.in-addr.arpa, NS, blackhole-2.iana.org
114.200.220.83.in-addr.arpa, unknown (this is the Public IP of the server, why is it unknown???)
