I have dns redirection enabled on my ccr, sometimes on router some issue happens and browsing does not work(dns servers drops out of router) and even we can’t login router and change the dns servers. after a while or reboot issue resolves.
(as many times before): you're asking for help with your problem. If you actually knew which part of configuration is relevant to fixing the problem, do you think you couldn't fix it yourself? In other words: since you don't know how to fix your problem, your idea about what's relevant is not relevant. So if you want people to help you fix the problem, better give them the information they're asking for.
Just looking at the image, you can see the bulls~~it of redirecting requests from port 853 to port 53, and with "redirect"...
That alone is a sign of someone who doesn't know how to configure the device,
and the rest of what he wrote indicates a more rude person than this response.
