I am facing a weird Problem.
I have a MT connected with ppppoe. I have two networks on ether2 and ether3. I have a DNS server(Adguard Home) on ether2(10.20.50.X/24). Here’s my Network diagram.
The problem is my DNS server is recieving DNS request from the gateway IP of the Network, not from the device/client connected to the network.
Here’s my router config
/interface pwr-line
set [ find default-name=pwr-line1 ] disabled=yes
/interface wireless
set [ find default-name=wlan1 ] band=2ghz-b/g/n country=bangladesh frequency=\
auto hide-ssid=yes installation=indoor mode=ap-bridge radio-name="" ssid=\
P2P wireless-protocol=802.11 wps-mode=disabled
set [ find default-name=ether3 ] arp=reply-only name=ether
set [ find default-name=ether2 ] arp=reply-only
set [ find default-name=ether4 ] arp=reply-only
/interface pppoe-client
add add-default-route=yes disabled=no interface=ether4 name=pppoe user=\
131
add name=LAN
add name=WAN
add name=MGMT
add name=dhcp_LAN ranges=10.20.51.60-10.20.51.70
add name=dhcp_SERVER ranges=10.20.50.10-10.20.50.15
add address-pool=dhcp_LAN disabled=no interface=ether lease-time=10h name=\
DHCP-AP
add address-pool=dhcp_SERVER disabled=no interface=ether2 lease-time=10h \
name=DHCP-SERVER
/routing bgp instance
set default as=100 disabled=yes
/snmp community
set [ find default=yes ] addresses=0.0.0.0/0 disabled=yes
set discover-interface-list=none
/interface detect-internet
set detect-interface-list=all
add interface=pppoe list=WAN
add interface=ether list=LAN
add interface=ether2 list=LAN
add interface=ether1 list=MGMT
add interface=ether1 list=LAN
add address=10.20.50.70/24 interface=ether2 network=10.20.50.0
add address=10.20.51.30/24 interface=ether network=10.20.51.0
add address=10.10.10.1/30 network=10.10.10.0
/ip cloud
set update-time=no
/ip cloud advanced
set use-local-address=yes
add address=10.20.50.0/24 dns-server=10.20.50.15 gateway=10.20.50.70 netmask=\
24
add address=10.20.51.0/24 dns-server=10.20.50.15 gateway=10.20.51.30 netmask=\
32
set servers=10.20.50.15,8.8.8.8
add action=masquerade chain=srcnat src-address=\
10.20.50.0/24
10.20.51.0/24
My goal is to get DNS requests from the individual device/client of my network.
I tried natting like this
everything works fine. but i can’t reach my AP’s(AP1, AP2) from RPi Network(ether2-10.20.50.X/24). The AP’s are normal home router, I disabled the DHCP server in order to use them as AP Mode.
I also need to reach my APs.
So its normal that ALL & ANY traffic will be NAT’ed/hidden behind the exiting interface IP even internally on your LAN because you only specifiy “src-address” and a packet from 10.20.51.45 towards DNS 10.20.50.15 will MATCH this NAT-rule so the NAT/masq is applied
You normally have 1 such MASQ-rule applied on the way to Internet! so basically change the 2 rules above towards 1 rules something like below where you specify outgoing “Internet” interface :
Thanks to you for your suggesion.I tried NATTing out-interface=pppoe
after applying this rule, i can’t reach my AP’s(AP1, AP2) from the RPi(ether2-10.20.50.X/24) network. I also need that working.
So you cannot even ping between them (eg. from AP > RPi or vice-versa) ??
On each device default-gateway was set OK?
I do not see any other FW-filter rule/entry on your config so all traffic normally is allowed between the segments 10.20.50.x <> 10.20.51.x
With the single masquerade rule in place, do your devices have Internet access ? (or does that even not work?)
Perhaps you have a network-design that contains IP-ranges that you don’t want to accidentally be able to reach the outside world ?
Sure you can have ip-filter rules for that, but making the SNAT-rule more detailed can also help. Its clear that such IP’s would never ever be going out in the event of other config errors.
I mean, there is dozens of reason, there is no good or bad way. Even if you want 5 masq-rules each for a certain /24 in your network that is not bad unless every cpu-cycle counts and you are into extreme performance tuning.
