Hello!
I was using SSH tunnel to get access to the Internet from my office (Mikrotik at home as a http-proxy).
Everything was working fine untill… I guess it was an ROS upgrade, but I cannot tell which because I don’t use this tunnel very often. Just spotted an hour ago it is not working.
The situation looks like this:
- on ROS: SSH is running on port 23 (a lot of robots were trying my password)
- on ROS: there is a REDIRECT from port 53 to port 23 (office firewall accepts all outgoing on port 53)
chain=dstnat action=redirect to-ports=23 protocol=tcp src-address-list=TrustedWAN in-interface=ether1-gateway dst-port=53
- on ROS: “:log info [:resolve google.com]” - gives me an answer. DNS from PCs from LAN at home are working (ROS as primary, 8.8.8.8 as secondary)
- on ROS: proxy enabled:
/ip proxy> print
enabled: yes
src-address: 0.0.0.0
port: 8118
parent-proxy: 0.0.0.0
parent-proxy-port: 0
cache-administrator: webmaster
max-cache-size: none
cache-on-disk: no
max-client-connections: 600
max-server-connections: 600
max-fresh-time: 3d
serialize-connections: no
always-from-cache: no
cache-hit-dscp: 4
cache-drive: system
- on office PC: Putty - SSH - Tunnels: ipv4 local 58118:localhost:8118 (and two other tunnels redirecting traffic to my PC in LAN at home)
- on office PC: localhost:58118 as proxy in my browser.
Now, whenever I try to visit a webpage I get
may/28/2012 10:01:26 ssh,error [[MY_PREFIX]]: unable to resolve hostname
I think something was upgraded too much in recent releases of ROS. Now I’m using 5.15, but as I said before - this change could be few versions earlier.
Please tell me is there a chance for me to fix it myself ? What to check?
