DNS server too high, even not using it
Hey y’all, I have and DNS server on my network, on IP 192.168.0.2, and I configured the DHP server on my mikrotik (192.168.0.1) to use my DNS server:
and configured the DNS on my mikrotik router like this:
But looking the process, DNS server is taking more than 16% to 30% of the CPU..
why is that? I’m not using DNS server on the router, or supposed to not be used.. what I did wrong here?
Thanks!
Regards!
When you are not using it: remove the “allow remote requests” checkmark.
What you are doing wrong: running router without appropriate firewall.
I uncheckd the allow remote requests and works… according to firewall, I have some rules for example blocking DNS from WAN, but nothing to deal with DNS on my LAN.
Simplify.
Block ALL from WAN, both input and forward.
Then only allow what you know for certain is needed.
