DNS server
I’m using router OS 6.17 . I would like to know how i can force users to use the DNS server provided in the mikrotik. because most of the users can go their PC ethernet card setting and change the DNS as they want.
I do not want this and i want them even if they change the DNS server on their PC still they should get the DNS i provided in mikrotik server.
thank you guys for your support.
regards,
Farhad
Force users to use specified DNS server.
yes true
I’m assuming your users are using windoze. If so, I think there is a setting you can get to
via group policies. You can remove a lot of stuff to lock down a system that way.
I can’t give specifics, been a long time since I retired, don’t do that stuff like I used to, I forget
some of the procedures, hope this helps - Jim
