DNS servers are not received via DHCP after reboot.
Hello!
DHCP client receives parameters from the provider. Received dynamic DNS servers are distributed to Wi-Fi clients. When I reboot the router, some clients connect immediately after the reboot, but do not receive the addresses of the DNS servers from the DHCP server. Apparently, because the DHCP client has not yet had time to receive DNS servers from the provider.
If I reconnect Wi-Fi on such a client, the DNS servers will be successfully received from the DHCP server.
As I understand, that this is a normal situation?
Is it possible to configure not to connect Wi-Fi clients until the settings are received from the provider through the DHCP client? Or just add my static DNS servers?
What can You advise me in this case?
