DNS Sinkhole
New feature request.
I would really like to run a DNS sinkhole on a router. These are awesomely powerful security tools…
http://www.dshield.org/diary.html?storyid=9037
Glancing through the links how is that different from transparently proxying all DNS traffic to the router local resolver and creating static entries for malicious domains that point to a machine you control? You could write an external script that downloads what they refer to as ‘sinkhole lists’ from the net and implements them via the API as a scheduled task.
All in all though if you’re going to be running a significant number of DNS lookups against such a sinkhole that would be best to do on a dedicated machine.
Haven’t we already established that MT DNS cannot handle large number of static entries: :smiley:
http://forum.mikrotik.com/t/ad-blocking-hosts-file/34766/1
DNS sinkhole list is 20k entries long…
So maybe the request should be better DNS servier in ROS :slight_smile:
Yes we established that 20,000 entries causes collapse. There is also a problem parsing as I remember. Getting the list into the correct form is a issue as well.
I would -really- like more access to the *nix directly. That would solve a lot of issues. Even allow 3rd party plug ins ? That would be a major cool feature.
Yes we 100% need a better DNS server. DNSMasq is good.
I doubt that’s going to happen, unfortunately.
Maybe KVM or a metarouter? Or a centralized BIND system all your routers can transparently redirect DNS to?
