DNS Static Servers Only
How can I completely remove the automatically populated dns servers “dynamic-servers” so the router only use the manually entered dns servers?
Using WinBox I manually added two DNS Servers by clicking IP->DNS. However I can still see the Dynamic Servers that were automatically populated from my ISP.
“ip dns print” in the terminal shows this:
servers ,
dynamic-servers: ,
Thank you.
Uncheck “Use Peer DNS” in the corresponding DHCP Client or PPPoE client interface configuration.
Thank you very much. This worked
Steps in WinBox:
IP → DHCP Client. Then double clicked on ether1and in the DHCP tab unchecked “Use Peer DNS”.
