So - I like to have use-peer-dns - however not all connectiuons are created equal and have some sites with ADSL and Satellite (Satellite FAST - but Latency is huge - DSL Slow - but lower latency)
Was considering building a script to check which connection has “Primary DNS” at any given time - and then maybe playing with a way to shuffle them about (Satellite drop and reconnect seems to do the trick - but i have no way to monitor yet)
So - in “/ip dhcp-client print detail” there is a field that shows up as “primary-dns=x.x.x.x” - and presume this is the same for secondary - however for the life of me, cannot find a similar feild for “/interface pppoe-client” or “/ppp profile” (although wasn’t expecting it there). This can be used to check against details from “/ip dns get dynamic-servers” - or that is the plan
Does anyone know where/how PPPoE Client hands off it’s DNS to “/ip dns”.
TBH, can probably just work with the one that I have - but being able to check for a positive and a negative results makes for… better… checks… bah - idk.
To anyone whom replies - cheers in advance.
