Do i need switch after RB1100AHx2 for local network
Hi, I have RB1100AHx2 router. After MikroTik i have to web servers and some workstations. For example, consider two case. In the first case we have a Hub and we know that, for example, the 2 port of MikroTik is connected to Hub and we can define ip address to this interface (2 port). In the second case we haven’t Hub (as my situation now). Please, tell me on which interface i need to define address in order to MikroTik was in local network. Thank you.
You can slave ports 3-5 with port 2 as the master. Assign port 2 address 192.168.0.254. Plug your PCs into ports 2-5.
If you move your public interface to port 11 you could group ports 1-5.
Thank you!
