Do I need the following firewall rules for CAPSMAN?
Following some guide in the forum, I ended up with this firewall rule in the process of setting up CAPSMAN (my router is my capsman):
add action=accept chain=input comment=“IN - CAPSMAN Local” dst-address-list=
“Loop Local” dst-port=5246,5247 protocol=udp src-address-list=
“Loop Local”
add action=accept chain=input comment=“IN - CAPSMAN LAN” dst-port=5246,5247
in-interface-list=LAN protocol=udp
Where:
dst-address-list=“Loop Local” = 127.0.0.1
Are they necessary? I don’t remember if it is something I added by following the guide or it was the CAPSMAN setup process that automatically added it (in which case it is fine as it is).
Thank you
This is to accept CAP from the same board where runs CAPsMAN.
Ah, that’s right. Thank you. Now I remember why I have this rule.
