logo
January 19, 2008, 9:32am
1
hi all
if got router that license is as follow
vincent@VERMAAK KOP] system license> print
software-id: “6R34-3TT”
upgradable-to: v3.x
nlevel: 4
features:
Put can not upgrade to soft 3 what am i doing wrong or can this not bee upgraded
thanks vincent
wirdo
January 19, 2008, 1:00pm
2
Type log print after uploading right files to your router (mips, risc, pc, etc…) and rebooting.
gmsmstr
January 19, 2008, 11:23pm
3
Make sure the file are in the root, and not under any folders. Hit system reboot and thats it.
and make sure you pick the right ros file. With the new v3.0 family they introduced a whole family depending on the processor, you wouldn’t be the first to make such mistake!
Rudy
logo
January 20, 2008, 7:10am
5
Thanks for all of your help
I installed it
thanks again
vincent
